Old 10-21-2017, 08:41 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Cracked canopy! WTB a new one.
Looks like I'll be down for awhile. Is there a source for tinted RV-8 canopies? Or does someone have one I can purchase?
Don't know why this happened. The canopy has served me well for 2150 hours and all kinds of abuse. It cracked on a 75-degree day. Go figure!
Canopy Crack by Ron Schreck, on Flickr
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 - Airbase Arizona
VAF 2022 Donor
Old 10-21-2017, 08:58 PM
snoop9erdog snoop9erdog is offline
Default G's
Probably some dem g forces
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 10-21-2017, 09:14 PM
SHIPCHIEF SHIPCHIEF is offline
Fix it NOW!
1) Use a cut off wheel to extend the crack all the way to the other side (so it doesn't go off in some other crazy direction).
2) Cover it with Sikaflex and an aluminum Targa stripe.
-Roll the aluminum strip in a slip roller to get the perfect cone shape and curve. Once you get it where it will lay in place, tape the SIKA boundary.
- apply the Sika & Targa strip. Push the Targa strip down into place until the SIKA is coming out the edges with no voids, and the join is slim.
-Then pull the tape with the pushed out Sika on it.
Looks good, lasts a long time.
https://www.harborfreight.com/30-inc...roll-5907.html (the top part)
http://www.jettools.com/us/en/p/sr-2...ip-roll/756020 (better graphic)
That will buy you time. You can still fly while you gather parts and get ready.
Mine cracked in the same spot, I did the Targa, and it looks good enough to keep.
I saw it first on an RV-4, they crack in the same spot.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-21-2017, 09:55 PM
VA Maule VA Maule is offline
Default Patch job
Assume you had a safe uneventful flight home. Did the patch job hold up adequately?
If you find a tented one let me know as I'm on the lookout for one as well.
Hopefully will see you up here next year.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 10-22-2017, 04:11 AM
ronschreck's Avatar
Morgan, thanks for the help. The patch held up nicely.
Scott, I have decided to take this opportunity to replace the canopy, rebuild the engine which has 2150 hours on it and repaint the whole airplane. It will be a long winter!
Ron Schreck
IAC National Judge
My Aerobatic Video
My Formation Video
VAF 2022 Donor
Old 10-22-2017, 06:04 AM
mike newall's Avatar
mike newall mike newall is offline
I sometimes wonder why guys who are unfortunate to crack canopies don't turn to the vintage and antique fellas for help.
Most of the warbird community have canopies and plexi repaired, filled and polished clear all the time. I remember seeing a plexi dome on a bomber being restored - it was in 5 or 6 pieces. After a couple of weeks work, you could not tell it was anything other than new.
We are tending to lose the old skills and methodology - my first thought with most things in maintenance is how do I repair it, not how do I replace it.
Obviously, there are caveats to all things, but it would be worth us as a community exploring repairs as they will always keep cropping up.
Dan H - any thoughts from you as a composite guru ?
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2021
Old 10-22-2017, 06:51 AM
ronschreck's Avatar
Appreciate your comments but I fear mine is beyond repair. It's really a nasty crack. I'm going to take this opportunity to ground the plane for the winter, install ADS-B Out, refurbish the interior, rebuild the 2150 hour engine and repaint the airplane. I would like to find a tinted canopy for the plane. Does anyone have contact info for Todd's Canopies? Are they still in business?
Ron Schreck
IAC National Judge
My Aerobatic Video
My Formation Video
VAF 2022 Donor
Old 10-22-2017, 07:21 AM
Hey Ron,
Yep, yours looks pretty terminal but I thought the thread grab was worth broaching the subject
Sadly, Todd is not with us any more, but you may look here.
http://www.vansairforce.com/communit...=130229&page=3
Donated in 2021
Old 10-22-2017, 08:27 AM
Scott Hersha Scott Hersha is offline
Ron,
Is there a rivet at the bottom of that crack? I'll bet there is...... I shoulda used Sika Flex......
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 10-22-2017, 09:51 AM
ronschreck's Avatar
Originally Posted by Scott Hersha View Post
Ron,
Your's was installed with professional guidance. Mine was done by an amateur eleven years ago!
Ron Schreck
IAC National Judge
My Aerobatic Video
My Formation Video
VAF 2022 Donor
