Old 10-20-2017, 07:46 PM
johnbright's Avatar
johnbright johnbright is offline
Default Electrically dependent engine - Dual Alternator Single Battery
Update... I changed to Z101 as a template when Bob Nuckolls published it in 2020. This will affect the relevance of some of the responses to this thread. I edited my responses in this thread appropriately.
I wanted to have a detailed drawing of my electrical wiring, electrically dependent, EFI + EI, so I sketched it using Eagle and also did a wire by wire failure analysis, engine start check list, and other documents.
I'm sharing my documents via google drive for those who may be interested. Feel free to reach out with any questions or comments.
https://drive.google.com/folderview?...QMvu4o1VEVyP4K
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 10-21-2017, 02:28 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Raise the bar!
Wow John, talk about raising the bar! Impressive set of documentation.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 10-21-2017, 07:48 AM
rvbruce rvbruce is offline
Default Dual Alternator
Looks good. Right out of the Bob Knuckles playbook. I have the 2 B&C alternators, V regs, and relays if you haven't all ready purchased.
Regards
Bruce
Old 10-21-2017, 07:52 AM
vic syracuse vic syracuse is offline
Super Moderator
Very well done! What standby alternator are you planning on using? A practice of mine is to use a very good one with enough capacity to not really have to make any changes to aircraft operation if and when it is needed. The newer B&C standby alternators that fit on the vacuum pad are rated for 40 amps. With our glass panels and LED lighting, that is enough capacity to run everything, including the pitot heat, all day long. Even at night.
No sense getting stranded when on a long trip away from home. 😀
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
Old 10-21-2017, 08:04 AM
johnbright's Avatar
Default Alternators etc
Regards
Bruce
I do not have those items yet. I sent you a PM.
Old 10-21-2017, 08:39 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Vic
Which model of the b and c standby alternators will give you 40 amps? I have a 410h and at 2400 engine rpm, it would generate around 30 amps. According to b and c's chart, it would have to run at 8000 rpm or around 6100 engine rpm to get 40 amps. Using the Lycoming ratio of 1.3 of course. Dazed and confused as usual
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 10-21-2017, 09:30 AM
johnbright's Avatar
Default 32 and 35 A pad alternators
B and C has two pad alternators, one delivers 32 and the other 35 A at cruise on Lycoming. Main advantage of larger one is output at lower RPMs. I summarized the spec'd outputs at the top of the "Calculations Measurements and Specs" spreadsheet in my folder "Engineering basic stuff".
Last edited by johnbright : 05-27-2021 at 07:50 AM. Reason: pad alternators are 32 and 35 A
Old 10-21-2017, 09:47 AM
rolivi's Avatar
rolivi rolivi is offline
Excuse the noob question.
I have a plane power alternator. Would I do better to go with their standby alternator, or with the B&C standby.
(I'm sure I'll hear I should replace the primary with B&C, which is of course an option since it's pretty low time)
Thanks.
And thanks to the OP for the detailed drawings.
Rob
RV-6A (Purchased)
2021 Dues Paid, of course
Old 10-21-2017, 11:35 AM
Toobuilder's Avatar
....With our glass panels and LED lighting, that is enough capacity to run everything, including the pitot heat, all day long. Even at night.
No sense getting stranded when on a long trip away from home. ��...
Dont mean to try pick a fight here Vic, but are you suggesting that in an "electrically dependent" airplane, you would launch with a failed primary alternator to get home? I've read many of your posts and you seem to be very conservative. The above appears to run contrary to this premise.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-23-2017, 08:33 AM
DanH's Avatar
DanH DanH is offline
Come on gents....John asked for a review. Let's stay focused on that.
John, my compliments sir. I've downloaded your work for study, and as a nice reference. So far the only detail I'd note is the wire #55 connection to the battery positive post. I'd move the connection point to the battery bus. It would work the same, but make the backup alternator connection immune to battery terminal corrosion.
Dan Horton
RV-8 SS
Barrett IO-390
