Old 10-19-2017, 11:29 PM
RicoB RicoB is offline
Default Baffle Sealing recommendation
I was told by several people not to use the baffling rubber material that vans put in their kits. I looked on AC Spruce and there are several choices. Could i get help on the best one to use and preferable size? Its for the RV9A -O320
Thanks a lot...
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 10-20-2017, 02:41 AM
rzbill's Avatar
rzbill rzbill is offline
Thats BS, It works fine.
Bill Pendergrass
ME/AE '82
Old 10-20-2017, 02:58 PM
Yes works fine if you want to replace it very soon. i have two friends that need to replace theirs already.
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
Old 10-20-2017, 03:21 PM
Ralph Inkster Ralph Inkster is offline
I've had to rework baffles that suffered from poor fit between cowl & baffle. Once that was accomplished, and Vans rubber seals fitted to lie smoothly against the cowl, I've not had to touch them again.
It's never the rubber seal's fault for kinking or rolling back.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 10-20-2017, 04:12 PM
DRMA DRMA is offline
My A&P recommended Cowl Saver from McFarlane Aviation when I the seals on my Grumman needed replacement. The seals work well and so far haven't had any problems.
Wally Anderson of Synergy Air also mentioned the Cowl Saver material as being better than the material that Van's provides with the kit.
Dave Macdonald
RV-10 First Flight April 1, 2020. Currently in Phase 1
2020 VAF Dues Paid
Old 10-20-2017, 04:16 PM
My Van's supplied baffle seals are 16 years old/1100 hours and are in great shape.
I think the Van's supplied product is fine. I also think there are individual preferences which lead to people upgrading quite a few items that work just fine for more expensive items that also work just fine, but may be prettier or otherwise be seen as an upgrade.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-20-2017, 09:06 PM
maus92 maus92 is offline
When I reworked my baffle seals two years ago, I used an unreinforced silicone baffling seal material. I regret that decision - it tears. Last year I replaced a torn section, and it looks like I will do the same this year in another location. I should probably be looking for a neoprene material reinforced with cloth / fiberglass.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 10-20-2017, 10:06 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I bought some 3/32 silicone sheet with a cloth reinforced center layer on Ebay.
It was too "floppy" to use for most of the baffling, but it works great for that strip that attaches to the cowling and rests on the inlet ramp. The floppiness makes it easier to grab and pull up when you install the lower cowling and it's flexibility made it easier to conform to the curves there.
I bought Vans stuff for the rest of the baffling and it seems to hold it's shape better.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-21-2017, 01:21 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default ACS
I used this: http://www.aircraftspruce.com/catalo...cowlseals2.php
Looks kind of cool, much more flexible than the Van's supplied seal. Can't tell you if it will cool better, since I'm not flying. It was easy to cut and shape.
Mickey Coggins
http://rv8.ch
"Hello, world!"
