  #11
Old 06-11-2020, 11:03 AM
1001001's Avatar
1001001 1001001 is offline
Originally Posted by mfleming View Post
Pressure increases and the temp falls = laws of physics ceased working
meh. something something dark matter something handwave.
Old 06-11-2020, 11:08 AM
AlpineYoda AlpineYoda is offline
Maybe a dumb question, but what cork gasket are you referring to?
I ask, because I happened to install my fuel senders in my RV-10 wings over the weekend. The senders that came from Van's with the wings had a black rubber gasket.
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Tail finished March 2020
Wings finished July 2020
Fuselage joined to tailcone on July 19, 2020
N1814T reserved with FAA
Donated through 12/31/2020, EAA and AOPA member
When it absolutely, positively doesn't matter when or if it ever gets there, ship with Old Dominion.
Old 06-11-2020, 11:12 AM
mfleming's Avatar
mfleming mfleming is offline
The -7 kit came with a cork gasket to seal the float mechanism plate. I't was suggested by Van's and Synergy Air that not using the gasket was a viable option. Apparently some of the cork gaskets would fail over time.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 06-11-2020, 11:13 AM
1001001's Avatar
I got rid of those rubber gaskets and just used the tank sealant. Worked fine on both tanks.
Old 06-11-2020, 11:46 AM
Draker's Avatar
Draker Draker is offline
I actually ended up using the cork gasket, but coated with Permatex "Aviation Form-a-gasket" including around each screw:
No leaks through the gasket, however both tanks still leak through the capacitive plate BNC connectors. Haven't figured out how to solve that one yet.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
RV7A Flyer's Avatar
I got rid of the whole access plate, and never cut the hole in the first place (but I have the capacitive sensors Van's used to sell...never a bit of an issue with them, knock on wood).
It can't leak if there's no hole there in the first place
2019 Dues paid!
Old 06-11-2020, 06:27 PM
DanH's Avatar
DanH DanH is online now
Shop leak testing is a good thing, but realize the real test comes when you G 'em up with 120 lbs of gas in 'em.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-11-2020, 07:19 PM
1001001's Avatar
Can't wait!
