Old 02-22-2007, 10:50 AM
Fallalloveryou Fallalloveryou is offline
Unhappy Sterba Wood Propellers
Can someone advise me if a 68x72 Sterba wood prop work on a 0-320 160hp Rv-9. Thanks
Old 02-22-2007, 11:59 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I can't advise you but will share this info: My Sterba prop on my 160hp RV9 is 70X79. Those numbers come from Vans recommendations and Sterba agreed with them.
I love my prop but am sacrificing some speed for it over a metal one. No plans to change, however.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 02-22-2007, 12:38 PM
hngrflyr hngrflyr is offline
When I purchased my 0-320 powered RV-6 it had a Sterba Prop that was
68-74. It worked well on my airplane. I replaced it with a 68-74 Catto Prop to tolerate the rain better. I would think 68-72 might not be enough pitch for good cruise, but it should climb great.
Bob Severns
Eugene, Oregon
RV-6
Old 02-23-2007, 09:20 AM
John_RV4 John_RV4 is offline
Default Just Call Ed
To the original poster:
Ed will sell you a brand new prop for about $600. If you can pick this prop up cheap to get you going, then that's fine. Otherwise, why not just order a new one ?
Good luck with your project.
John
Old 02-23-2007, 12:31 PM
339A's Avatar
339A 339A is offline
I have a Sterba 68 by 76 on my 9A with an 0320. It has performed real well and I have no complaints at all. I am getting a new Catto prop next month, trying to get better top cruise speed. It should be quieter also. The Sterba prop is quiet in its own right. As long as the Catto prop performs as advertised I will probably sell my Sterba. It has 190 hrs on it but I will send to Ed to be refinished first.
If your interested let me know.
Scott Mills
339A
Flying out of Front Range CO
C 303 909 7105
