Old 02-22-2007, 09:21 AM
Camillo Camillo is offline
Default Wing tip trailing edge alignment
Hello to everybody.
I'm now experiencing my wing tips. I had some trouble in perfectly aligning the tip trailing edge with the aileron. I think that a perfect alignment is crucial, provided that the tip trailing edge misalignment should work as a positive/negative aileron, thus increasing resistence if both wings have a right/left tendency or if they have a roll toward right or left which pilot or a trim should correct.
Best technique should be the following (second tip; first tip went in a different way): adapt the tip leading edge to the wing leading edge (heating could be useful). Trim exceeding material from tip edges. Fit it on the wing. Set aileron on neutral position. Clamp an aluminium angle along with aileron and tip trailing edges. Drill #40 holes. Check, heat, reinstall and open to #30. Install first rib. Check again. Install second rib, etc...
Any other suggestion?
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
