02-21-2007, 01:57 PM
Lightspeed Ign. power connection
Wondering what others are doing. I am wiring up my Lightspeed Plasma 2 Ign. The instructions state to run the power wire directly to the Battery posts to help avoid noise.
If I do this, I will have about a foot and a half of un-protected wire ( no fuse ) in the cabin area that could cause some problems if grounded somehow. There is a 5 AMP breaker called for but, this is near the switch. Are others using the battery buss with a fuse or breaker near the battery or a fuseable link in line with the power wire directly connected to the battery?
Robert RV9A
02-21-2007, 02:48 PM
Yes.
You can use an inline fuse, fusible link, or battery bus. Your choice.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
02-21-2007, 02:49 PM
I ran my Plasma II off my always-hot battery bus (fuse, not a breaker) instead of following directions to a T.
If you do wire from the battery directly, you could put an inline fuse close to the battery connection so that if the wire does short to ground somewhere between the batt & your breaker/switch, the fuse would blow instead of wire frying.
My feeling was -- and I don't speak for everybody here -- the likelihood of the always-hot battery bus going "cold" is slim to none. Just my 2 cents.
Dan Checkoway RV-7
02-21-2007, 03:49 PM
I agree with Dan. I ran one system from the battery bus (with the appropriately sized fuse), and the other system directly from the backup battery. I did use an inline (automotive blade style) fuse right near the battery. The backup battery is charged through a diode and another inline fuse from the main battery.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
02-21-2007, 04:18 PM
Thanks for the replys guys. Spent I don't know how many hours going over this question, searching Bob's site and the archives. Just want to do it right the first time.
Thank's again
Robert
02-22-2007, 09:04 AM
When I added the 2nd LSI
I went direct to battery for power. The #1 system in on the hot battery bus so just in case something happened there I have an alternate source.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
