Old 02-21-2007, 12:54 PM
striker striker is offline
Default TUG FOR RV-6A
Our new hanger requires us to push the plane up an incline into the hanger. Has anyone used a tug ( electric or gas ) that accepts the low profile of the RV with a nose wheel pant? Many thanks for any input.
Pete Joslin
RV-6A 110.5 hours
IO-360 ECI Titan Engine
Sam James Holy Cowl
Old 02-21-2007, 01:12 PM
Mel's Avatar
Mel Mel is offline
Default Pull instead of push?
Have you considered an electric winch in the back of the hangar? With a long switch cable you can guide the plane while pulling it up the incline. This is what I did when I had a similar situation with my Mooney. Much cheaper than a tug.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-21-2007, 01:46 PM
mikegraycmg's Avatar
mikegraycmg mikegraycmg is offline
Default tow
I thought about doing that with my bonanza, but I was afraid I'd stress the tail.
Mike Gray, A&P IA, AET, KGPM, Grand Prairie, Texas
1956 Bonanza for sale.
Old 02-21-2007, 02:28 PM
N941WR's Avatar
N941WR N941WR is offline
It doesn't sound like this will apply to your hanger but ...
A friend used an electric winch to pull his Stearman in and out of his hanger.
He would insert a piece of bart sock with a pulley attached at the top in a hole out in front of his hanger. Then he would run the winch cable under the plane out to the pulley and back to the plane.
When it was time to put the Stearman way, he just connected the cable to the tailwheel.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-21-2007, 05:08 PM
flyeyes's Avatar
flyeyes flyeyes is offline
Pete Joslin
RV-6A 110.5 hours
Sam James Holy Cowl
I have used the gas "towbars," lawn tractors with hydrostatic transmissions, and electrice golf carts.
My preference is the golf cart if you can find one used, because it's useful to have around the airport. You'll need a sturdy, secure towbar and may need to modify the golf cart slightly.
The elctric carts will generate an amazing amount of torque, and need minimal maintanence. I've owned one for years, and used to push a Cessna 337 up a ramp with it (3500#)
Sometimes lawn tractors can be had cheap, and they work well, but are terrible for running around the airport (might as well walk).
James Freeman
RV-8 flying
Old 02-21-2007, 07:54 PM
Vern's Avatar
Vern Vern is offline
Default Battery powered hand unit
I have one in the hanger. It works great but with 6 RVs in the hanger, each type needs its own fork to fit either nose or tailwheels. The old style nosewheel pants are not as wide as the newer type. If you get the correct size fork it will work well for you.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 03-12-2007, 02:26 PM
grahamcalder grahamcalder is offline
Default battery tug
Just what I need!!
Where can I buy one?
Rgds
Graham
