Old 10-06-2017, 01:33 PM
mfleming's Avatar
mfleming mfleming is offline
Cool Flamemaster Say's No Touch-up
So I need to touch up my fuel tank mounting plate (Removed one of the float plate screws. Mounting plates not yet installed).
Called Flamemaster and asked if touching up ten day old sealant was OK. After hemming and hawing the tech said...no touch up.
What's the real world consensus?
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 10-06-2017, 01:45 PM
blueflyer's Avatar
blueflyer blueflyer is offline
did he say what his reasoning was?
Old 10-06-2017, 01:58 PM
mfleming's Avatar
No he didn't.
At first, he said he could not know the condition of the sealant and then he cut himself off and said no touch up...
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 10-06-2017, 03:03 PM
rvbuilder2002's Avatar
If by touch up you mean putting some sealant on the screw you removed, and reinstalling?
That type of thing is done all the time. As long as the area being sealed is clean and the new sealant is mixed properly you should have no problem.
Scott McDaniels
Hubbard, Oregon
Old 10-06-2017, 03:37 PM
mfleming's Avatar
I decided to remove all the sealant off the one screw and start fresh.
But what I originally meant was... Can I add sealant on top of clean sealant that has been curing for about ten days?
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 10-06-2017, 04:15 PM
Flame master may say know but many years of field experience says that it works just fine.
Scott McDaniels
Hubbard, Oregon
Old 10-06-2017, 04:17 PM
Here are two pages from a tank sealant installation guide. As you can see, it's virtually impossible to avoid putting sealant on top of cured sealant.
and
Assuming that the underlying sealant was properly stored, mixed and applied, it's fine.
By the way, a "mill" is .001 inch or 1/1,000 inch. So 250 of those small things is 1/4 inch.
Dave
Old 10-06-2017, 06:38 PM
DanH's Avatar
DanH DanH is online now
I dunno about consensus, but here's a quote from Flamemaster's own Sealant Application Guide, Rev III, 2007:
Accomplish repair of undersized fillets after the expiration of the application time of the existing sealant as follows:
a) Clean the sealant and surrounding.
b) Apply additional sealant and fair onto existing sealant per in such a manner that the prescribed configuration is produced.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-06-2017, 06:44 PM
mfleming's Avatar
Dave
Thank you!
The Flamemaster tech did seem confused at first...now we know why
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
