Old 10-04-2017, 11:14 AM
rwarre rwarre is offline
Default 180 hp o320
Like to visit with anyone who has converted an o320 to 180hp. Currently have a o320 150hp, and looking at options for more hp.
Old 10-04-2017, 11:19 AM
N941WR's Avatar
N941WR N941WR is offline
I converted an O-290 D2 135 hp engine to an O-360 188 hp. It was easy, just write a check and spend time in your shop fitting it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-04-2017, 01:35 PM
titanhank's Avatar
titanhank titanhank is offline
This will take some work, but can be done. Polish the cylinders, 10-1 compression pistons, dual p-mags will get you 175+hp out of an 0-320. If the engine is apart for overhaul, go with the 0-340 stroker option. If your engine is an old 150hp e2d with the small front bearings and no cylinder hold down plates, then i would not attempt to get 180hp out of it.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
