I have never experienced PIO in an RV. I did experience it in a Moni motorglider. I was at the extreme aft end of the CG range during the flight testing phase. The problem with PIO is that as by definition, the pilot is causing it by "chasing" pitch with the elevator. The cure is to STOP chasing and hold the stick rigid. the aircraft will then stop oscillating. Power will NOT help.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
