Old 02-20-2007, 09:12 AM
prkaye prkaye is offline
Default tank to join plate
Well I got things aligned pretty well by pulling the tank down with ratchet-type shipping straps. The fit is actually very good (just ahve to check for twist as advised in the plans).
QUESTION - I can't find anywhere in the plans a call-out for what planenuts and screws to use for the tank skin to 919 join-strip (the strip to mate the tank and leading edges together). Is it the same platenuts&screws as those for the tank skin to main wing spar? K1100-08 / AM509 8R8 ?
What size dimple die do I use for these?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 02-20-2007, 11:57 AM
Bruce Reynolds's Avatar
Bruce Reynolds Bruce Reynolds is offline
Default W-919 Joint Plate
See DWG 9, Section D-D. Use a dimple die for a #8 screw.
Bruce Reynolds
Rv-6A
