Old 09-27-2017, 03:13 PM
bobnoffs bobnoffs is offline
Default copper tubing and AN fitting
hi all,
i want to use a piece of copper tubing with a AN 816 fitting. alum. 3/8'' tubing has a wall of .035'' and copper tubing wall is .032. can i flare the copper tube and use it with the 816 fitting?
this is only for diverting the flow of a return line inside a fuel tank. is there another fitting i should use?
and i am only looking at copper because i want to solder a finger screen to the end of the tube.
thanks for any input.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 09-27-2017, 04:16 PM
rv7charlie rv7charlie is offline
I wouldn't hesitate to do it, if I needed to use copper. I've even done it to copper tubing when I was prototyping a line from cockpit to wing, though I never tried to run fuel through it. On the other hand, have you thought of just using safety wire & tank sealant to attach your screen? Take a look at the fuel pickup tubes Van supplies for the older 2 seat kits.
On another note, do you really want to further aerate the fuel returning to the tank?
Old 09-27-2017, 07:09 PM
Originally Posted by rv7charlie View Post
....have you thought of just using safety wire & tank sealant to attach your screen? Take a look at the fuel pickup tubes Van supplies for the older 2 seat kits....
That's exactly the way Van's did mine when I bought them for my RV-3B project: safety-wired and tank sealant.
Dave
Old 09-28-2017, 04:45 AM
ok,
i assume for the alum. tube it is as basic as beading the end of the tube, slipping a finger screen over and safety wiring and sealing?
Bob Noffs
n. wi.
Old 09-28-2017, 12:51 PM
I think that it might not be beaded. It was pretty simple.
Dave
