Old 09-25-2017, 06:05 PM
RicoB RicoB is offline
Default Advice on the MAP sensor
I have installed my Dynon MAP sensor on the engine side of the firewall. ( I spoke with Dynon and it?s perfectly fine to install it there) my question is what hose or tubing should use coming out of the the restricted AN4 fitting provided by VANs? I also have 2 Pmag to T off to. I found a clear pulse tubing on aircraft spruce. Would that be ok?
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 09-25-2017, 09:01 PM
219PB 219PB is offline
My EFII kit came with black tubing that looks like automotive fuel lines.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 09-26-2017, 08:28 AM
Yeah looks like few guys use the SS line to the firewall because it came with the kit, but to simplify things since I have to run lines to the pmags I want to stay with rubber rubbing just wonder what kind should I go with
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
Old 09-26-2017, 09:09 AM
lr172 lr172 is offline
You can get rubber vacuum line at the auto parts store. Be sure to get vacuum line, as it is thick enough to handle high vacuum with crushing. 5/32" is the most common size, but they should have several sizes. Fuel line is pressure rated and not vacuum rated (different design).
Larry
Old 09-26-2017, 11:30 AM
Raymo's Avatar
Raymo Raymo is offline
Call Tom at TS FlightLines and he'll hook you up with everything you need to connect the P-Mags and MAP.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
