Old 09-24-2017, 11:00 PM
ron sterba ron sterba is offline
Question Would you install a ANL 50amp fuse
Was considering installing a fuse holder on my 9A firewall with a 50 amp fuse that would feed my main buss in the cockpit. This fuse holder would be installed near my Master relay, on the engine side of the firewall. Has anybody done this? What kind of fuseholder/ block would you use. I saw one on a firewall once that was about 3" long in black color & with a plastic clear cover. It had a 50 amp fuse. I believe they call them ANL fuse? Quarter inch hole on one end and a "U" shape on the other. My condition inspection is due shorty. Any ideas always appreciated. Thanks
Ron in Oregon RV9A N421HJ just one away from the Honda Jet and a whole lot more fun to fly! Course unless you are in a hurry.
Old 09-25-2017, 05:12 AM
vic syracuse vic syracuse is offline
Super Moderator
What you described works fine. B&C specialty has pictures of them on their website.
http://www.bandc.aero/anlcurrentlimiterbase-1.aspx
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 09-25-2017, 05:46 AM
bret's Avatar
bret bret is offline
I have three 80 amp ANLs, one from the B+ PP 70 amp alt, another one to feed the plane after contactor, and one at the backup 20 AH battery.
Old 09-25-2017, 05:50 AM
Deweyclawson Deweyclawson is offline
Default resettable/replaceable in flt?
It sounds like this would be a serious failure if it occurred in flt. I think I would want it accessible if it blew in flt.
Dewey Clawson
Super Sabre Society
2012 RV10; 1993 RV6A; 1947 Cessna 140, in progress
2019 dues exempt but paid anyhow
F100, A7D, A10, F16,
Fokker, Boeing, McDonnell-Douglas
Old 09-25-2017, 06:34 AM
Super Moderator
It is common practice to put these on the firewall so you don't have a hot, unprotected B-lead running directly into the cockpit, as was practiced for many years.
If you have a 60 amp alternator, use an 80 amp limiter. I have never had one blow. They are very slow to blow, not like a CB or normal fuse, and are there to mainly protect against a dead short.
I highly recommend using one. Have been doing it for many years, as have others.
Vic
Vic Syracuse
Old 09-25-2017, 06:53 AM
DanH's Avatar
DanH DanH is offline
Plus one on everything Vic says.
Vic
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-25-2017, 07:03 AM
RicoB RicoB is offline
I have a plane &power 60amp alternator I used a 60amp ANL, is that the wrong amperage?
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 09-25-2017, 08:28 AM
AlexPeterson's Avatar
Should be ok - have a look at the specific data sheets for that fuse, it will show the time to open vs current.
I used this brand - it shows as a minimum opening time at full rated of about 4 hours..., max opening time at rated of infinity. They are designed to be matched to the alternators. 120s opening time minimum, 30 minutes maximum, at 135% of rated.
http://www.littelfuse.com/~/media/au..._datasheet.pdf
That brand is about $7 plus a couple dollars shipping from Digikey.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 09-25-2017, 08:53 AM
Captain Avgas Captain Avgas is offline
I do not think that Bob Nuckolls recommends a fuse ( or ANL limiter) on the power supply from the master to the main bus. He states his reasons for this in the AeroElectric Connection Manual. He does however recommend one be used at the firewall end of the alternator B lead. This "fuse" must obviously be rated beyond the maximum current output of the alternator. This "fuse" is to protect the alternator (and the B-lead running from the alternator) in the event that there is a short to ground in the diodes at the alternator resulting in a full battery current surge to the alternator.
Having said that I do believe there are obvious very real pitfalls in discussing these type of electrical architecture decisions on VansAirforce without reference to an actual drawing. Too easy for novices to get confused.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 09-25-2017, 09:08 AM
DanH's Avatar
I can think of both pros and cons, but tell us why Bob doesn't like it.
It just protects the airplane. The B-lead is running through the engine compartment, an area full of hot and vibrating things. Short the B-lead through worn or melted insulation, or break it away from the B-terminal, and it can short to almost anything in the compartment with full battery amps.
Dan Horton
RV-8 SS
Barrett IO-390
