The air forward of the firewall isn't necessarily bad, only the potential to be bad with leaks. Don't forget that there is a huge amount of clean cooling air flowing through the cowl at any time, making any bad components a small percentage.
I can't imagine that any of the small leak points that you mention can make a meaningfull impact given the large volume of, theoretically, clearn air coming from the heat muff.
Larry
