09-21-2017, 12:32 PM
Oil Quantity (IO-360)?
Hi All,
basic question but figured I ask.... My IO360 manual states no more then 8qts and some ridiculous number of no less then 4qts.
I have been hovering at about 6 qts. Is that acceptable or should I play it safe and keep it at 7?
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
09-21-2017, 01:10 PM
6
6 quarts is adequate for operation in all attitudes, and has always been my minimum level at takeoff. In my experience, and often reported, 7 or 8 quart level leads to venting overboard to a stable level at 6. Look to your engine manual for more info. I think you will find that minimum for takeoff is 4 quarts, just FYI -- not recommending.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworked: N4032Q RV8A (8/2017)
Building: S-21 Outback/Titan, tail and cockpit mated (3/2020)
KELY/Ely, NV
09-21-2017, 01:29 PM
Cold air sump?
Does a Superior cold air sump change anything concerning the quantity?
My guess is that due to its construction, the oil pan itself lost a bit of the volume (to take oil) compared to a standard oil pan.
Therefore the level of the oil, lets take 6 qts, is slightly higher and will be vented overboard.......
So what is the oil quantity if you use a superior cold air sump?
What do the guys do who already fly behind an IO-360 with superior cold air sump?
Mit Fliegergru
RV-8 QB Germany
ECi XIO-360
Dynon SV
Flying since 11th July 2020
09-21-2017, 01:33 PM
Mit Fliegergruß
You'll likely need to re-calibrate your dipstick to the new sump but the amount should not change, if I recall.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
09-21-2017, 01:37 PM
re-calibration of the dipstick is necessary!
I am just curious about the quantity!
Mit Fliegergru
RV-8 QB Germany
ECi XIO-360
Dynon SV
09-21-2017, 01:48 PM
5 qtz on the dip stick (in the sump), +/- 1 qt in the filter.
Any more and mine will just dump the extra.
When I change oil, I fill with 6 qtz with a new filter. It will always find its level on the dip stick right at or near 5.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
09-21-2017, 03:00 PM
Mit Fliegergru?
An email to Superior asking if the capacity for my O360-A4M would remain at 8 qts received the following response:
"Yes, it remains at the same capacity"
I plan to do this upgrade in the next 6 months.
Ray
09-21-2017, 03:20 PM
for the 4 bangers I consider 6 "Full", and add when it drops below 4.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
09-21-2017, 05:47 PM
Careful with the original dipstick for the IO-360-M1B. As the Lyc service bulletin about dipstick replacement intimates, the level marking below 6 Qt is incorrect. I have not changed mine yet but during an oil change after the SB, I filled one quart at a time and watched the dipstick. The 4 Qt mark is definitely in the wrong place and the area under the 6 Qt is not visually linear. Actual contained oil drops really quickly when the oil shows below 6 Qt.
As a result, I have gotten into the habit of keeping the level right at 6 Qt by adding 1/2 Qt when needed.
Bill Pendergrass
ME/AE '82
09-21-2017, 05:58 PM
A very respected sage who cashed quite a few paychecks from Lycoming Engines taught me that every engine has a 'happy spot' when it comes to oil level. The IO-360 I fly is around 5.5 qts. The O-320 I fly is around 4.75 qts. Anything more than those quantities on those particular airplanes ends up on the belly of the airplane. YMMV.
Mike C.
Sierra Nevada
RV-6A bought flying
