  #11
Old 09-21-2017, 03:14 PM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by tspear View Post
Why? (Both why not sell, and why would they want it without the log book)
Tim
The buyer would have likely put the engine on a certified plane and went flying or sold it to an unknowing buyer.
As an A&P mechanic (mostly Blackhawk experience but drinking from the hose of knowledge every day), I could not have that on my conscience.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 09-21-2017, 04:26 PM
tspear tspear is offline
Raymo,
Agree. Just never even occurred to me. I am probably a little naive in the bending/breaking rule aspect.
Tim
Old 09-21-2017, 06:41 PM
Bevan Bevan is offline
Oh ****. I did not think of that. It never even occurred to me.
Tim
And likely the liability will come back to the person who neglected to make the log book entry.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Raymo,
Tim
Unfortunately true. Some ads say "No damage HISTORY". With no log entry, there's no "History".
Old 09-21-2017, 07:21 PM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
If you are looking to buy an engine that has had a Prop strike and hasn't been tore down, then you have to consider that engine as core value only. I know some here will disagree but if you want to be safe then consider making an offer to the seller for core value only.
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 09-21-2017, 07:32 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
And that core value is only valid if the crank checks out OK.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-29-2017, 01:30 AM
Marc Bourget Marc Bourget is offline
An unmentioned issue is what is the proper way to check the crank.
A friend of mine is a long time auto engineer. He was on several initial design team for new OEM engines in Detroit.
The generally unknown factor that leads to a wide variance in damage is the timing of the strike. If the prop contacts almost anything just as a cylinder firing pulse lights off, the loads go to Valhalla.
A 3000 amp Magnaflux machine may check to about a depth of .375", but it was easy with prop strikes to develop fracture planes deeper than that.
He would not use a "prop strike" crank unless it had been examined with an industrial X-ray machine.
YMMV
Old 09-29-2017, 05:45 AM
maniago's Avatar
maniago maniago is offline
Originally Posted by jibby212 View Post
I have been searching for an o360 for my rv7 and have found many which have had a prop strike. There is a o360 a1a WITH 346 SMOH for 12950 on Barnstormers but it has had a prop strike, flange dials good but I have a feeling that don't mean a lot. I'm thinking I should stay away from these engines but any professional opinions would be appreciated.
From my 3yrs search for a 360 motor, $12950 is in the range of acceptable prices for a used motor with good books, good oil analysis and recent run history and serviceable/useable accessories. With a prop strike its the suckers price. If you want to know the real price its worth, ask a rebuilder (who wont BS you) what hed pay for it. But yeah, drop the zero maybe add 1k to it and youre in the ballpark from what I've heard and seen.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 09-29-2017, 08:10 AM
jibby212 jibby212 is offline
Thanks for the opinions, I will stay away from these engines for sure. I have a little time yet so I will just keep looking.
