VAF on Twitter:
@VansAirForceNet
Old 09-21-2017, 12:54 PM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default VFR waypoints
I'm currently planning a VFR flight, and on the VFR chart there's a number of small red flags scattered about the area I'll be flying thru. These are 'VFR Waypoints' according to the chart key, but they're supposed to be accompanied by a 5-digit identifier starting with 'VP' (i.e. VPKRG - I just made that up). However, none of these flags that I'm looking at have an identifier. What are these used for? How will I identify them from the air?
Below is a link to a SkyVector screen grab of an area just north of Flint, MI. I've circled seven such flags. This is my first time trying to link a picture to one of my posts, so I hope it goes thru.
[IMG]<a href="http://tinypic.com?ref=10n9xj4" target="_blank"><img src="http://i64.tinypic.com/10n9xj4.jpg" border="0" alt="Image and video hosting by TinyPic"></a>[/IMG]
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
50 hour oil change: 8/29/19
Old 09-21-2017, 01:00 PM
Raymo's Avatar
Raymo Raymo is offline
My understanding is that they are used when planning to enter class B or C airspace while VFR. They're usually an airport or easily identifiable object a pilot can use to notify ATC of their position.
Your pic:
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 09-21-2017, 01:07 PM
YellowJacket RV9 YellowJacket RV9 is offline
Those are VFR checkpoints, meant to be easily identified from the air to describe your position to ATC. Some are associated with waypoints which do have an identifier, but not all.
http://www.treetop.academy/Chart_Leg...waypoints.html
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 09-21-2017, 01:47 PM
Logan Logan is offline
And the names for those check points are the underlined words. Springfield, for example, in the chart image above.
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
Old 09-21-2017, 01:53 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Yes, the VPxxx ones are most likely in your aviation GPS database and can be set as flight planning waypoints.
The rest of them would probably have to be added as User Way Points., which might be worth it for your local ones.
I found the VPxxx ones very useful navigating the LA Basin airspace.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
