See link for my post about the wire topic.
http://www.vansairforce.com/communit...d.php?t=152266
Congrats on the call back!
FYI: things you will need in addition to Pmags.
I purchased several packages of spark plug wire seperators from the auto parts store.
You will need a mag gasket for the Pmag...or two for dual.
You have to figure out the manifold pressure tubing connections. I had Tom make me a new MP hose to replace the standard Van's hose with a TEE in the line. Worked very well.
I did remove the long studs that hold the impulse mag on and replaced with shorter ones. Brad sells these too. PS..the stud extractor tool is sold at the auto parts place for 12.00...wise investment.
Wire per plans....I used pull type breaker.....and a label for the panel also. I also purchased a firewall pass through for just the Pmag harness to run through.
