Old 02-18-2007, 05:51 PM
mtown52 mtown52 is offline
Default Painting inside of RV-9
OK-which is best for inside painting? Gloss or semigloss? No doubt that will cause trouble. Mike In Tasmania...
Old 02-18-2007, 06:05 PM
db1yg's Avatar
db1yg db1yg is offline
Mike,
Use either satin or semi-gloss. I used satin. You probably don't want reflective surfaces inside the aircraft.
Best Wishes,
Dave B.
RV9a/ECi0360/James cowl/Catto prop--110 hrs and a permanent smile!!!
Old 02-18-2007, 06:41 PM
Scott Will's Avatar
Scott Will Scott Will is offline
Have a gloss finish on mine. Thought it would be a big deal but it really isnt because once you get everything in there, a lot of the interior is hidden by either seat cushions or people in those seats. Mine interior is the same color as Van's powder coat.
I would do gloss again. You want a finish that is hard and easily cleanable and resistant to most solvents.
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 02-18-2007, 09:24 PM
ClayR_9A's Avatar
ClayR_9A ClayR_9A is offline
Default how about flat?
I used gloss automotive paint (Acrylyd) for my interior and it was the worst month of the entire build process. As a first time painter, getting it to lay down flat and smooth with no runs, drips, errors, dust, etc. was way more difficult than I thought it was going to be.
If I ever do it again, I'll seriously consider something flat or maybe satin. Shooting primer was a breeze. Shooting this stuff was like painting with milk.
Make sure you spend a little time with someone who can show you several types of paints, how to apply them, and what the result is going to look like.
-Clay
Clay R- RV9A - Flying since 2004 - 400 hours
VAF dues paid through end of 2020.
Old 02-19-2007, 11:59 AM
airguy's Avatar
airguy airguy is offline
What about powder coating the interior surfaces? Aside from the obvious cost issue, how much weight does powder coating add?
Old 02-19-2007, 12:05 PM
fehdxl fehdxl is offline
I don't think it would be the weight, but rather the logistics of baking the powder coated parts for 20 minutes at 350* ... that would be one big oven, or an expensive IR light. -Jim
Old 02-19-2007, 12:08 PM
Jekyll Jekyll is offline
Not to mention the heat treatment of the metal!
Jekyll
Old 02-19-2007, 02:13 PM
Finley Atherton Finley Atherton is offline
Mike,
I used automotive gloss paint with the same brand ?flattening additive? for the instrument panel and interior and I am very pleased with the result.
Fin 9A
NSW Australia
Old 02-19-2007, 07:42 PM
airguy's Avatar
Jekyll
Hadn't considered that - definitely a showstopper.
Old 02-19-2007, 08:01 PM
gvgoff99's Avatar
gvgoff99 gvgoff99 is offline
Default Heat
Somewhere I saw an informed answer to the powder coating heat issue and it was not a factor. Van's powder coats the engine mount (not very well in some cases because they rust) but still he is subjecting them to the powder coat heating process. I doubt that he would if it were to induce significantly earlier failure from some heat related change. Chrome is a different situation and I believe it does cause a potential problem.
As for the interior paint........I have a light color and it is a problem with reflection on the canopy when the sun is behind the plane. So if I had it to do over (and I just might because it is really a nuisance) I would go with a darker color or even a flat black. Mine is glossy. Maybe a flat would have been less annoying.
George Goff RV-6A (Flying 3/7/2006 )(Houston, TX)
