Old 09-14-2017, 10:46 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Alternator field switch required ?
Installing B&C system with regulator, OV function etc. The field is protected by a 5A circuit breaker and the output is protected by an ANL current limiter which I assume would protect the buss from an internal short in the alternator. So, my queustion is: Why would I need a FIELD switch ????
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 09-14-2017, 11:04 AM
Mich48041 Mich48041 is offline
There needs to be some way of shutting off the alternator in case of smoke in cockpit. If the circuit breaker also functions as a switch, then a separate switch is not necessary.
Shutting off the master contactor will NOT shut off the alternator once it is running because the field will be powered by the alternator output, not by the battery. In fact, once the engine is running at high enough RPM, everything is powered by the alternator, not by the battery. The battery is still required after engine start to help stabilize the electrical system voltage.
Joe Gores
RV-12 Flying
Old 09-14-2017, 11:35 AM
krw5927 krw5927 is offline
Mitch is spot on. I don't have an alternator field switch for my primary nor my backup B&C alternator. Both are protected instead by pullable breakers on the panel in case all electrons need to be manually shut off.
I have verified that turning off the master in flight, while disconnecting the electrical system from the battery, does not stop the alternator from producing power. Pulling the breaker stops it instantly.
Kurt W.
RV9A
FLYING!!!
Old 09-14-2017, 03:57 PM
bret's Avatar
bret bret is offline
From my understanding, the ANL will blow at a particular % over rated current but will still carry high voltage to your components, this high voltage will fry some electronics.
Old 09-14-2017, 04:14 PM
Bicyclops Bicyclops is offline
Default ANL
The ANL is like an extremely slow blow fuse. It is there to protect the B lead and the alternator from the battery. It won't protect anything from the alternator. Say you have a B&C 40 amp alternator and a 40A ANL. The alternator will happily put out much more than 40 amps for a while if the battery was run way down and the ANL won't blow. It will probably suffer twice its rating for quite a long while. If there is a dead short, it will blow immediately because the battery will try and shove a thousand amps through it. It also does not care what the voltage is. You need an overvoltage sensor and/or "crowbar" device to blow the field breaker if the alternator runs away. The crowbar acts in milliseconds and will probably save your avionics.
Ed Holyoke
Old 09-14-2017, 05:59 PM
Default Thanks for the high quality response.
My conclusion from all of this is that the CB works as well as a switch in a runaway scenario, and' IF the OV relay fails the Avionics will fry before you can react. Thanks much ....Larry
Larry DeCamp
Clinton, IN
Old 09-14-2017, 07:47 PM
FasGlas's Avatar
FasGlas FasGlas is offline
It has always been a common practice to start the engine before turning on the alternator, field switch. It wouldn't matter how you did this, a switch or a breaker.
Old 09-14-2017, 08:54 PM
gasman gasman is offline
37 years of master and alternator on during start with no problems.
I do shut off the alternator if I am sitting in the RV and playing with the panel.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 09-14-2017, 10:01 PM
rv7charlie rv7charlie is offline
[edited out; bad info]
Old 09-15-2017, 12:13 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Ed Holyoke
If you have an external Voltage Regulator this crowbar function is often built into it. Just like this Plane Power one -
http://www.chiefaircraft.com/pp-r1224b.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
