w/a Donation
VAF on Twitter:
@VansAirForceNet
  #1191
Old 08-30-2023, 06:36 PM
JLuckey JLuckey is offline
Default Which Clear Coat over Instrument Panel
Hey Mike,
I'm building a panel for an RV-14 and we are going with a color scheme very similar to yours. Dark-ish gray with white dry-transfer lettering. I want a satin/non-glossy clear coat.
I have a couple of questions:
1. What are you using for the final clear coat?
2. Is there any issue w/ clear coat adhering to a glossy finish powder coat?
TIA
Old 08-31-2023, 08:15 AM
toolmanmike toolmanmike is offline
My panel is primed, and rattle can gray enamel that I found to almost match my interior.
After that I just shot standard clear over. To my knowledge, clear will stick to anything except water base paints. I’ve never had an issue. Might try a small sample first. My finish is a gloss though. Haven’t tried a semi-gloss clear.
Other projects though a so I gloss poly out of a can has worked well.
Toolmanmike
PA, USA
RV-7 sn75068
Emp done.
Wings done
Fuselage-?? Working on it!
Dues paid
