Old 09-11-2017, 07:07 PM
ssokol ssokol is offline
Default Starter Recommendations for IO-320 160 HP
Well, my starter decided to die this evening. Fortunately I was at a neighboring field. Any suggestions for a replacement? The engine is by Aero Sport Power of Canada. From what I recall, the starter is original to the build in 2001.
Thanks!
-S
Steve Sokol
Cedar Park, TX
RV-6A N101PR at 40XS
Open Flight Solutions - Maker Of FlightView EFIS
(VAF Supporter / Advertiser)
Old 09-12-2017, 08:52 AM
Raymo's Avatar
Raymo Raymo is offline
Most install a SkyTech or BandC brand. There are several to choose from, with varying weight and robustness (if that is a word).
If I had your engine with standard compression, I'd go with one of the lighter versions - unless you need more weight for CG concerns.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 09-12-2017, 10:08 AM
Default A semi-religious topic
From perusing the archives it looks like starters are another semi-religious topic in the RV community. I talked it over with a couple of friends here in the KC area and decided to spend a few extra bucks on the B&C.
The weight differential (10.2 vs 17.2 pounds) frees up enough weight I can now install my ~5 pound EarthX backup battery, mounting bracket, and cabling on the firewall without too much concern for altering the W&B.
Steve Sokol
Cedar Park, TX
Old 09-12-2017, 11:50 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Starter recomendations
I would recommend the Sky-Tec 149-NL for a 14V system or even better but only offered for 28V systems is the 149-NL/EC. I ran these starters at a flight school on a dozen+ aircraft with good results. Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
Old 09-12-2017, 09:14 PM
RV6_flyer's Avatar
The SkyTec NL starter or the B&C starter are the two that have held up the best / lasted the longest / broke the least.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-13-2017, 05:21 PM
Default Night and day
Amazing how much better a modern starter works. Swapped in the B&C and WOW - it spins the prop at least twice as fast. Cold start was probably no more than 3 or 4 blades. Hot start took a couple of seconds, but much better than before.
Thanks, VAF!
Steve Sokol
Cedar Park, TX
