09-11-2017, 02:21 PM
Co-locating Build Space with Woodworking
Hi,
I'm in the process of getting my work space set up and laying everything out. I have a 20x40 detached garage that was formally RV storage (not the flying kind lol). I currently have my woodworking gear in one of my attached 2-car bays, but a recent addition to the household (GF) has me needing to clear out that bay.
My question is: Does anyone do occasional woodworking in their RV build space? Aside from the obvious issues of getting dust on/in everything is there any other reason not to? I intend to have a sealed off paint booth area with filtered air.
I guess I'm just wondering how much of a PITA I could potentially be causing myself and thought I'd see what other experienced builders might have to say. Thanks
09-11-2017, 02:32 PM
Just manage your dust going both ways. An RV build can produce quite a bit of aluminum dust when finishing edges, etc....
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
09-11-2017, 02:36 PM
Hadn't considered that, but it makes sense. Thanks!
09-11-2017, 03:42 PM
At my favorite makerspace, cutting aluminum in wood shop is not allowed because the hot shavings can ignite the wood dust inside dust collectors. You won't be using a circular saw or CNC router on your RV, so if you use common sense in managing your flammables you should be OK.
Not directly related but this seems like a teachable moment: there are wood finishes that will spontaneously burst into flames if you leave soaked rags in a wastebasket. Use vented metal wastebaskets and pay attention to where your VOCs go...
09-11-2017, 05:05 PM
You can also use a lot of your woodworking tools on the build: band saw, table saw (carbide tipped blade), belt sander, disc saner (both table mounted).....
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
09-11-2017, 07:03 PM
I have a full woodworking shop in my walk-out basement. I also built my RV-6A down there. I did not do much to control the Al dust, but I do have an elaborate wood dust collection system. No issues with either material dust.
Noel
RV-6A N6NF
tip-up
flying
09-11-2017, 07:17 PM
Work shop
I do but I vacuum and sweep between work sessions. Some of the tools get used for both so they get cleaned and vacuumed as well. Sounds like a lot of work but if you make it routine, it's nothing.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
09-11-2017, 07:21 PM
I have both wood work and the RV in the same space. I have to clean the RV periodically, no big deal.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
09-11-2017, 08:05 PM
Yeah I figure I might pick up a dust collector, and make sure not to use it when I'm cutting aluminum...
Glad to hear others do the same without issue.
Thanks for the input!
