Old 09-11-2017, 11:41 AM
sblack sblack is offline
Default Plug for Oil Filter Adapter
I have a B&C oil filter adapter. It has a 5/8" x 18 threaded hole for the temp probe. The accessory case has the same hole. I only have 1 probe so I have to plug the hole. I can't find a straight threaded plug (I can find lots of npt plugs but that doesn't help). Should I just stick a short bolt in there with a crush washer?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 09-11-2017, 02:09 PM
krw5927 krw5927 is offline
For $20 you could plug the hole with a Dynon oil temperature sender and have a hot spare.
Kurt W.
RV9A
FLYING!!!
Old 09-11-2017, 02:11 PM
Whatever you choose, don't forget to safety wire it.
Old 09-11-2017, 08:51 PM
rackley16 rackley16 is offline
https://www.pegasusautoracing.com/pr...asp?RecID=1147
Maybe this and a copper crush washer would do the trick.
Old 09-12-2017, 05:32 AM
Perfect! Thanks!
Scott Black
VAF dues 2020
Old 09-12-2017, 08:58 AM
659JR 659JR is offline
Default plug
A 470/520 oil drain plug would work and normally around 5.00. also comes with safety wire holes. You should be able to get one from a local engine shop.
Jesse
Colorado Air Parts
Old 09-12-2017, 09:34 AM
even better. Thank you. Gotta love VAF.
Scott Black
VAF dues 2020
Old 10-22-2017, 11:04 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Jesse
Colorado Air Parts
Jesse, Scott,
Is there a part number for the 470/520 plug? I'll be needing one soon too.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-23-2017, 08:01 AM
Default plug
Plug number is 532432 or superior makes it SA532432 and a MS35769-11 gasket. I have them in stock if you cannot find them locally.
Jesse
Old 10-23-2017, 10:20 AM
Jesse -PM sent.
Carlos in Arizona
