Old 09-10-2017, 09:14 PM
atalla atalla is offline
Default Machine countersink depth question
Hello all.
I'll cut right to it.
.32 E702 Spar
4 AD426 rivets to the E705 root rib
When counter sinking the spar as per the directions in section 5 of the manual I am not able to get the rivet to sit flush without the hole being enlarged. Will this rivet squish in after setting? I don't want to go any deeper and cost me a spar see pictures.
Thoughts?
Andrew Atalla
Red Seal Automotive Service Technician
Red Seal Heavy Duty Equipment Service Technician
Welder/Fabricator
Squamish BC CYSE
RV-7 Left Elevator in progress
Dues paid
Old 09-10-2017, 09:20 PM
You need to go deeper. Set your countersink cage practicing on scrap.
Old 09-10-2017, 09:24 PM
I agree but as you can see I'm about to enlarge the hole?
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 09-10-2017, 09:28 PM
PilotjohnS PilotjohnS is offline
Default Rivets
In my experience, rivet heads will not smush down. If the machine head is proud to start, it will end up proud after riveting.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
Old 09-10-2017, 09:45 PM
I see you work in the automotive industry. Are you sure your countersink is an aircraft one, not an automotive one? Different angles.
Old 09-10-2017, 10:42 PM
tgmillso tgmillso is offline
If you end up with a slightly proud factory head, you can always shave them down with a rivet shaver bit in your countersink cutter cage driven by your trusty 1800rpm drill (the fancy 20,000+ RPM pneumatic shavers are not necessary).
Tom.
Old 09-10-2017, 11:01 PM
1001001's Avatar
1001001 1001001 is offline
If you are concerned about the csink moving around, make a backing plate from a piece of thick aluminum or hardwood and clamp it in place. Match drill to the pilot size and then countersink. Reuse the backer until it wears too much.
Old 09-11-2017, 03:47 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default 032 should be dimpled ?
I may be wrong, but recall Vans instructions say don't CS on less than 040 for this reason.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 09-11-2017, 07:56 AM
I am using the 100 degree '0' flute cutter from Cleaveland tool.
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 09-11-2017, 09:02 AM
John Tierney John Tierney is offline
If this is an RV-7 I think you should be dimple countersinking the HS spar, not machine countersinking.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
