Old 09-09-2017, 07:07 PM
Richard Connell Richard Connell is offline
Default Centre Section Bulkhead #10 Countersink
I think I'm going mad.
Ive drilled all the WD-1021-PC Landing gear mounts to the bulkhead with a #12 drill as instructed.
I need to machine countersink the 2 holes shown for a #10 screw.
My #10 countersink pilot clearly won't go in a #12 hole.
What am I missing?
How do I countersink these holes. Is such thing as a #12 pilot countersink?
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 09-09-2017, 07:38 PM
berck berck is offline
Confusingly, you need a #12 countersink cutter, because the cutters are hole sizes not screw sizes.
A #10 countersink cutter is worthless to us, but I suspect that you, like me, got the Cleaveland RV kit which comes with one. It should have come with a #12 countersink cutter for #10 screws, but instead came with a countersink cutter that not only will we not use, but which will confuse us at every opportunity.
I had the same problem at the same time, ordered a #12 cutter.
Old 09-09-2017, 09:52 PM
Thanks Berck
That makes perfect sense. Thanks for clarifying.
The #10 cutter has been sitting in the tool cabinet unused since about 2003.
Never used it on the -7.
#12 ordered!
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 09-10-2017, 02:19 AM
Tassie Tassie is offline
Default Landing gear mounts
Hopefully you have a large hammer in that toolkit, to beat the landing gear mounts into submission.
Adrian Port
RV-10 emp done, wings 90%, fuse 90%, cabin top DONE!
www.tasrv10.com
Old 09-11-2017, 04:18 PM
Ha. Not too bad thankfully Adrian.
No issues getting them aligned and drilled on the center section.
But It's early days!
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 09-12-2017, 08:18 AM
rvanstory's Avatar
rvanstory rvanstory is offline
FWIW, my tool kit (from Isham) had a 3/16" countersink in the kit. I used that and it worked just fine for #12 holes.
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020 / Current Hrs - 225
Donation Happily Made 2022
