Old 09-07-2017, 11:19 PM
Robin8er Robin8er is online now
Default Older Carb
I have an older marvel schebler carb for my lycoming O-360. The guy I bought it from said it was rebuilt, and I believe him, but it does look used and like its been sitting for at least 10 years. Just wondering what precautions should be made. Is there anything in it that would go bad from sitting? Its a pretty important part so I want to play it safe.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 09-07-2017, 11:37 PM
jrs14855 jrs14855 is offline
Default carb
360 and 320 carbs are very similar. I took my 320 carb apart, replaced the throttle shaft, installed a LEGAL metal float, new gaskets and reassembled. You should have the applicable manual and a torque screwdriver that covers the lowest applicable torque. Pretty simple carb.
also check for one piece venturi.
Old 09-08-2017, 01:30 AM
Where do you get the manual/parts? Ive tried searching for a rebuild kit but cant find one.
RV-8 N695RA flying
Working on an RV-4
Old 09-08-2017, 05:29 AM
Default parts
I got parts from Spruce, Marvel Schebler and some of the aftermarket mfg. I shopped best price except for the metal float.
I think I got the manual on ebay.
I will try to remember to check the manual when I get home in about 10 days. I don't think it covers the MA4-5 but it may. I know it covers many of the earlier carbs.
Old 09-08-2017, 08:05 AM
William William is offline
Be sure to check the condition of the pump plunger for the accelerator pump. The plunger itself is made of leather material and will dry out. Check for the proper float height, and proper (updated) float installed as there were issues with past floats.
Take care
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
