What is the Allen Nut just left of the screen plug
I have a new IO-360-M1B from Vans and there is a nut plug with an Allen wrench hole just to the left of the screen plug, down on the oil sump, aft side.
What is this Allen nut plug?
The drawings in the installation guide don't show. Other drawings on line for M1A show it but don't tell what it is.
thanks
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
thanks
If it's the one on Page 46 (item 12) it seems to be open to the sump.
If you check Raven and Christen documents (or one of the RV Aerobatic pilots), I bet you will find that plug is used when adding an inverted oil system.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours Where is N157GS Building RV-8 S/N: 80012
