Old 02-16-2007, 06:59 PM
robjohnson's Avatar
robjohnson robjohnson is offline
Default Anyone have CAD drawing specs for altimeter???
I am making some reasonably good progress at laying out our panel in AutoCAD 2000, but I am having some troubles finding the detailed specs of the "bump-out" for the altimeter. This is the lower left hand corner where the adjustment knob is. I have tried to look the specs up, but I can't find them anywhere. Adding to the problem is the fact that today is the very first time I have ever messed with AutoCAD, so I am quite the novice. Does anyone have this drawn out for their panel in a DXF format??? I would greatly appreciate it!!!!
Thanks!
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
1945 Piper J3 Cub - sold
RV-10 - wings with fuselage ordered
https://www.rv-builder.com
Old 02-16-2007, 07:36 PM
az_gila's Avatar
az_gila az_gila is offline
Default Dimensions here....
Try these dimensions from Falcon Instruments... they are in metric, but should be OK to translate....
http://www.falcongauge.com/PDFs/diagrams/alt20inf-3.pdf
I'll send a .dxf by private e-mail, but check the file against the dimensions on the spec. sheet...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-16-2007, 09:32 PM
ToddA ToddA is offline
Default Nice drawings to copy from
There are some really nice CAD drawings listed at the bottom of this page: http://www.cafes.net/leo/RV-6.html
I copied/pasted many objects out of these while working on my panel.
Todd
Old 02-17-2007, 07:30 AM
Mel's Avatar
Mel Mel is offline
I wouldn't make to cutout until you have your instrument. They are NOT all the same. I've seen slight variations between manufacturers.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-17-2007, 08:24 AM
robjohnson's Avatar
Default Thanks!
Thank you everyone for the great response on this! Also, thanks for the sound advice on waiting until we have our actual instruments, Mel. That would be a pretty ugly mistake.
Thanks again!
Rob
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
