Old 09-04-2017, 09:53 PM
lr172 lr172 is offline
Default Looking for help Computing Drag Impact
I will be adding an ads-b antenna, similar to my transponder antenna. I am wondering if it is worth the cost/hassle of going to blade style antennas.
According to Rami, the rod and ball antennas has .41 lbs of drag at 250mph and the blade has .09 lbs at 250. I would be reducing .8 lbs of drag at 250 mph.
Not being an aeronautical engineer, I have no idea how that number translates to improvement in airspeed on an RV cruising at 160 knots.
Can anyone help me ballpark the speed improvement?
Larry
Old 09-04-2017, 10:07 PM
scsmith scsmith is offline
Default drag x velocity = power
250 mph = 367 ft/s
The equivalent power for the small drag you describe is 0.8 lb x 367 ft/s = 293 ft-lb/s.
1 Hp = 550 ft-lb/s. So your drag change is equivalent to a power change of 1/2 Hp.
Thats at 250 mph.
160 kts = 184 mph = 270 ft/s.
At that speed, the equivalent power is 0.8 lb x 270 ft/s /550 = 0.4 Hp.
For constant drag coefficient, power varies in proportion to velocity^3, so assuming you are using 180 hp to go 160 kt at sea level, the speed increase is approximately, (0.4/180)/3 x 160 = 0.12 kts.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 09-04-2017, 10:14 PM
Originally Posted by scsmith View Post
250 mph = 367 ft/s
Thats at 250 mph.
At that speed, the equivalent power is 0.4 Hp.
Thanks for the help and detail. Can I assume that the speed obtained with that added .4 hp is a small fraction of .4 in MPH?
Larry
Old 09-04-2017, 11:09 PM
Larry
Original post updated to include estimated speed increase
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 09-05-2017, 05:44 AM
6 Gun 6 Gun is offline
Smile Drag
Looks like a great project for our VAF bros. with the 3D printers to make a blade cover for transponder antenna.I want one. Hope Steve Melton sees this.
Bob
Old 09-05-2017, 06:46 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Bob
Why not just buy a real blade antenna from Delta Pop? They're super cool, reasonably priced, and work as expected.
website
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 09-05-2017, 06:52 AM
rv7charlie rv7charlie is offline
website
Homebuilding mentality?
DIY philosophy?
300% price delta over the spike?
Old 09-05-2017, 07:28 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Curious about 2 things
1. Steve said, "speed increase is approximately, (0.4/180)/3 x 160 = 0.12 kts." Not sure where the "/3" term comes in. Feel like there should be a ^-3 function in here somewhere. But I'm NOT a math guy.
2. Have noted for some while the auto industry's use of spiral-fluted automobile antennas, presumably for reduction in vibration seen in smooth rod broadcast receive antennas on car fenders. Is there a drag reduction to be gained from tripping the boundary layer with a spiral flute like this? Might be a compromise design between blade and rod-and-ball antennas that we could implement?
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 09-05-2017, 07:39 AM
airguy's Avatar
airguy airguy is offline
The spiral flute on the auto antenna is there to prevent vortex shedding which will cause the antenna to whip back and forth perpendicular to the airstream.
Old 09-05-2017, 07:51 AM
1. Scott said, "speed increase is approximately, (0.4/180)/3 x 160 = 0.12 kts." Not sure where the "/3" term comes in. Feel like there should be a ^-3 function in here somewhere. But I'm NOT a math guy.
I bet he just got lazy with the keyboard when he typed the formula. I did a cube root of that ratio, & got around .13.
