Old 09-04-2017, 02:50 AM
RicoB RicoB is offline
Exclamation Fuel, brake and oil lines sealer recommendations
I am in the process of dealing with brake lines, fuel lines and oil lines. What sealer should I use? Would fuel lube be good for all of them? Thanks for the help!
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 09-04-2017, 03:32 AM
tgmillso tgmillso is offline
Fuel lube for all is a bad idea. There are heaps of posts for this, but you will find that most people end up using Loctite 567 for tapered threads. Fuel lube is for lubricating tank cap o-rings etc, but generally not for sealing threads. You should dig into some of the archives.
Just one example thread:
http://www.vansairforce.com/communit....php?p=1086970
Regards,
Tom.
Old 09-04-2017, 07:49 AM
lr172 lr172 is offline
I don't think fuel lube would be good for any of them. I like permatex #2 for NPT threads and it will work well for all the applications you listed. Use sparingly near the first thread.
Larry
Old 09-04-2017, 07:57 AM
622BH 622BH is offline
Default NAPA Indian Head Gasket Shellac
An "old" IAP recommended NAPA Indian Head Gasket Shellac for such fittings. I resisted at first, but when I just couldn't staunch two weeping fittings on the brakes I gave in and tried it. Immediate cessation of the problem. SO, I took all fittings loose and applied the shellac now flying for over a year without any indication of weeps, runs, or errors.
The Shellac is around $5.00 for a bottle. DO NOT use the dauber that comes with the bottle. I use a Q-Tip to apply, works great and requires virtually no clean up.
Old 09-04-2017, 09:37 AM
BillL BillL is offline
Permatex #3 or #2 for good for engine/oil, but Loctite 567 for the brakes.
I have some evidence that the Royco 782 brake fluid will dissolve the #2 and #3.
Bill
RV-7
Lord Kelvin:
Old 09-04-2017, 10:07 AM
Default ONLY ON THE NPT THREADS-
only seal the NPT threads for the master cylinders, reservoir, calipers, and the flow transducer if used. NOTHING on the flares or the threads.
Tom
Ridgeland, SC
Old 09-04-2017, 10:22 AM
Jesse's Avatar
Jesse Jesse is offline
I use Seal Lube for all NPT threads.
Jesse Saint
Old 09-04-2017, 11:22 AM
Thanks guys for your inputs!
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
Old 09-04-2017, 11:46 AM
RV10Pilot RV10Pilot is offline
From the plans section 5.27.
"Because we cannot always fully tighten tapered thread fittings, and because even after fully tightening the fitting a small spiral leak path remains along the full length of threads, a thread sealant must be used during assembly. Sealants appropriate for use on aircraft NPT fittings are Tite-seal, Permatex #2 and Locktite 565. Do not use RTV, Teflon tape or Fuel Lube on NPT fittings."
Old 09-04-2017, 01:48 PM
snopercod's Avatar
Default Pneumatic and Hydraulic Sealant
I used MRO Solution 34 Low Strength Purple Hydraulic/Pneumatic Sealant on all pipe threads. It's the cheaper equivalent of Loctite 545. Loctite 545 Technical Data Sheet.
(2020 dues paid)
