Old 09-03-2017, 08:16 AM
Robb Robb is offline
Default Amp meter Draw
My Rv7 always shows about 7 amps when I key the mic on my Garmin 430. I also see my manifold gauge drop a lot at the same time. It has always done this but does not seem to be a safety issue. I am going to have it looked at when i have the ads b out installed just wondering if anyone has an idea of what's up
Dues paid gladly
Old 09-03-2017, 09:25 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
1 - What kind of Ammeter? EFIS or Analog
2 - What kind of current sensor? Shunt or Hall Effect.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 09-03-2017, 10:17 AM
rv7charlie rv7charlie is offline
The fact that an unrelated gauge is affected would indicate poor connections somewhere in the system, likely grounds, or ground path issues (ground loops).
What grounding philosophy did you use when wiring the plane?
Old 09-03-2017, 10:52 AM
Not really sure how it was grounded as I did not build it. The gauges are all analog
Old 09-03-2017, 11:09 AM
erich weaver's Avatar
erich weaver erich weaver is online now
I don't think so. More likely he is getting radio frequency interference, with one or more wires acting as an antenna. Can be hard to chase this down. On my -7A I get a fuel pressure warning on the EFIS whenever I key the mic.
Erich
Old 09-03-2017, 11:13 AM
GalinHdz's Avatar
This is the highest probability and the hardest to hunt down. Start with the radio antenna cables, connections and attachment to the fuselage. Check for broken, loose wires or corrosion somewhere. After that check all wires (especially the ground wires) starting with the affected gauges.
Good luck. These kind of gremlins are a PITA to track down.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 09-03-2017, 11:18 AM
rvbuilder2002's Avatar
Another potential cause is leaky coax routed beside un or poorly shielded wire connected to an instrument.
RG400 coax is less likely to cause this than RG58.
Scott McDaniels
Hubbard, Oregon
Old 09-03-2017, 01:44 PM
Thanks Guys
Old 09-03-2017, 05:58 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Mine turned out to be "coiled" wiring
If you have extra wire coiled behind the panel, get rid of it by trimming the wiring, or laying out the wires in a "non-coiled" fashion. I was getting an ammeter spike when I keyed the mike.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 09-03-2017, 06:26 PM
jweir43 jweir43 is offline
Take a 4" square of aluminum foil, wrap it around a wire or a bundle of wires, and slide it along the wire(s) until the goosey readings stop. If you are using a bundle of wires, take them one by one and see which one kills the interference. Repeat, lather, repeat until you've checked every wire in the airplane.
At these frequencies, RG58 is every bit as good as RG400. That's the LAST resort, although a loose termination on the coax braid WILL cause the problem. The al foil will find this fault also.
Jim
