Old 09-02-2017, 08:56 AM
lndwarrior lndwarrior is offline
Default Ammeter wiring backwards?
If I wired an ammeter backwards, reversing the load side, would the meter simply read backwards or would it fail to work?
Tia
Gary
Old 09-02-2017, 09:28 AM
DRMA DRMA is offline
If this is the typical ammeter that shows both positive and negative current, driven from a shunt in the circuit, wiring it backwards should just reverse the reading.
Dave Macdonald
RV-10 First Flight April 1, 2020. Currently in Phase 1
2020 VAF Dues Paid
Old 09-03-2017, 09:23 AM
Default Vans: of it's wired backwards it's ruined
Answered my own question. Apparently some ammeter gauges will read reverse if wired backwards.
However, I have a Vans gauge and the installation institutions clearly say that if it's wired backwards, it's ruined.
For those doing this for the first time don't make the same mistake I did. The "load" side pig the gauge is the wire from the alternator.
And, yes, another reminder to carefully read install instructions...
