08-31-2017, 09:09 AM
Prepping for paint is heartbreaking ...
Taking scotchbrite to those perfect aluminum panels you've worked so hard to protect .. sad, sad day ..
(prepping cabin for paint)
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
08-31-2017, 02:22 PM
I found my loop - hook DA sander holds the scotch brite pads very well and speeds up the process. They work great for smoothing out fiberglass too.
Have fun!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
08-31-2017, 02:28 PM
I did the same thing but it will no longer hold sand paper when your done, my experience anyway.
08-31-2017, 09:53 PM
I never understood why people spend so much time with a straight edge and soldering gun. Unless you are going to polish.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
08-31-2017, 09:59 PM
A new bottom for a Dewalt is $12 at HD. Worth it. I took my old one, cleaned it off and now can use it for pressure glue sanding discs.
rockwoodrv9a
Williamston MI
O-320 D2A
09-01-2017, 04:13 AM
Protection helps. My skins don't look perfect but leaving the plastic on helps with the minor hangar rash. It'll still have to get scuffed for paint but the less blending I have to do to remove minor damage, the better.
RV-7ER - finishing kit and systems installation
09-01-2017, 05:12 AM
Don't forget you want to primer or whatever you are using as soon as possible after scuffing before the aluminum starts to oxidize, paint stuff don't stick well to oxidized aluminum
09-01-2017, 09:16 AM
Good practice, but that is partly what the etching process does, rids the skin of oxidation. It may be more critical that you top coat within a specified time depending on the systems you are using. Leaving primer on for extended periods may require you to go back and rough up again before your top coat.
Ideally, your paint prep and painting all occur together within a few days for most systems.
I wouldn't waste time prepping until you're ready to go: prep/prime/paint.
It is a LOT of work.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
09-01-2017, 09:48 AM
this is good advice. increases your chance for good bonding.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
09-01-2017, 08:19 PM
When to paint
In a much larger scope of when to paint. Do any of you know if any DARs have objected to the plane being painted prior to the inspection? Wondering if they want to see every rivet.
Tried to contact a couple of tech counselors and would have asked them but none return my calls.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
