Originally Posted by Larco
Most of the north side hangers have a 20 AMP breaker. Some of us plug into the socket with a 15A power strip because it is a real hassle to call the airport every time the 20A CB trips. A 1.6HP compressor should be fine.
Thanks for the quick reply. Does each hanger have its own dedicated 20amp breaker? So if you pop the breaker you can't gain access to the circuit breaker box to reset it? How are the lights in the hangers? Will they allow you to add some additional hanging lights?
Thanks Again for the help.
