Old 08-29-2017, 07:39 AM
Radioflyer Radioflyer is offline
Lucky for me, lycomings have a "flywheel" with 12 perimeter holes, 30 degrees apart, where I can mount the optimal bolt/washer/nut counterbalance. An earlier post mentioned that balance was effected by directly modifying (e.g., spot painting) the prop. I guess on engines without a flywheel nor spinner backplate, this is the easiest route toward dynamic balancing....if you happen to be lucky enough that the rotational inbalance is along the length of the prop. Otherwise, I don't see how you can satisfy a polar plot inbalance by just working on the prop.
Old 08-29-2017, 08:25 AM
n18pf's Avatar
n18pf n18pf is offline
Our chapter recently bought the ACES 1015. I've helped do three planes so far, all Lycoming. It's very easy to use, just follow the instructions on the screen. As was mentioned it allows you to split the weight to two angles. So if it wants weight at 78 degrees, you say you want to split it at 60 and 90 degrees and it gives you the amount of weight at each of angle. Like I said, just follow the instructions.
Paul A. Fisher
RV-7A N18PF
Q-200 N17PF
APRS track
Old 08-29-2017, 08:30 AM
13brv3's Avatar
13brv3 13brv3 is offline
Thanks for the report. I had a 2020 years ago, and it looks like the 1015 works the same for standard dynamic balancing. It lacks a second channel, and doesn't have any vibration spectrum analysis, but I don't recall ever using those anyway. The 2020 was really impressive if you do your part, and by that I mean giving it correct angles and measuring the weight you add precisely.
Rusty
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 08-29-2017, 09:40 AM
az_gila's Avatar
az_gila az_gila is offline
In general, for metal two-bladed props, isn't the imbalance always along the length of the prop since that is where the longest moment arm is?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-29-2017, 11:11 AM
MercFE MercFE is offline
Not necessarily, as you are balancing the prop and engine together.
Old 08-29-2017, 05:33 PM
Walt's Avatar
Walt Walt is offline
You can't balance the engine by balancing the prop.
If you're bored I have lots of good info posted on my webpage about prop balancing toward the bottom of the page under "Theory":
http://expaircraft.com/PropBalance.htm
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-30-2017, 08:03 AM
GWZ GWZ is offline
Default Stupid balancer questions
I'm planning to balance my prop soon and have some basic questions.
I'd like to use the "flywheel" holes to add weight as needed.
1. Should I use 1/4" hardware? If yes then if the weight needed is less than the weight of a bolt/washer/nut, I would add a similar combo 180 around then fine tune with washers or is it acceptable to use smaller hardware in the 1/4" hole in the flywheel.
2. Is it OK to do full power runups with only the lower cowl on? I've seen photos of runs with just the upper cowl off and some with both halves removed. I've looked at prop balancing videos but haven't found any that go into the, dare I say "nuts and bolts" of the operation
Thanks, Gunther
Gunther
2002 RV-9A 150hp
Old 08-30-2017, 08:44 AM
Walt's Avatar
Thanks, Gunther
I have used 3/16 hardware when the weight of the 1/4" is to much, when doing this I make sure to tighten down the bolt at the edge of the hole so it can't migrate outboard on its own with the centrifugal force. I generally balance at 2400 which is a good cruise RPM but less than full power. I've not had any problem leaving the bottom cowls on an RV.
Old 08-30-2017, 11:51 AM
az_gila's Avatar
Smile
My mechanic used 1/4 inch AN4 hardware on my flywheel. Installed identical nuts and bolts at two holes 180 degrees apart.
Final balancing was done by adding either AN960 or AN970 washers to the light side only.
Gil Alexander
Old 08-30-2017, 12:49 PM
Walt's Avatar
I've tried this as well, and theory says that should work, but the reality is balancing with 3 positions vs 2 (as is normal) does not work very well and most often leads to additional run time to get things tweaked with the end result being no better. The bolts don't carry any load other than their own weight, they just need to stay in the holes.
