08-23-2017, 11:41 PM
INFINITY STICK GRIP WITH RAY ALLEN SERVO
Hello Gents
I'm in the process of converting my RV-4 Pitch Trim from manual to electric and also using an Infinity stick grip with a Dynon A/P Panel for auto Trim
My question is...Do I need to install the Ray Allen Relay Deck with the Ray Allen Servo when using an Infinity Grip Coolie Hat and the Dynon A/P Panel??
I've read conflicting comments....Some say Yes and some say No...
So is there anyone who has done it who can tell me the real answer???
Also: For RV-4 Owners using an Infinity Stick Grip:
Where did you exit the Blue wire bundle from the grip ?? At the Bottom or did you drill a hole in the stick ( If yes, did you have to re-enforce the stick ) ???
Thank you for your imputs
Bruno
rv4@videotron.ca
08-24-2017, 07:45 AM
Bruno
rv4@videotron.ca
Bruno,
No need for separate relays when using the Dynon AP panel. Installing both will cause issues.
In my -7A, I drilled a hole near the pivot point for the bundle to exit. The primary reason for doing this was to limit the amount of wire movement with the stick. If you run the bundle out the bottom, you will need to ensure it will not chafe or interfere with anything, which will be difficult.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
08-24-2017, 03:04 PM
Infiniy Stick Grip
Hi Raymo
That is what I thought and glad I don't need to install the relay
Would you have a picture of your install you could send me by any chance??
Bruno
rv4@videotron.ca
08-25-2017, 10:00 AM
Not a great pic but should help.
Ray
08-25-2017, 02:13 PM
For the Infinity grip with the Dynon A/P panel, take the common wire from the trim hat to ground, then run the up and down wires to the A/P panel pins 3 and 4 respectively, then run pins 7 and 8 to the two white wires on the Ray allen motor. You will also need power to pin 9 and ground to pin 2 on the A/P panel 15-pin connector.
Jesse Saint
08-25-2017, 04:55 PM
Is there any special relays or wiring needed when you are planning on using trim in both stick grips with the Dynon AP panel?
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
08-25-2017, 05:35 PM
Separate pins for pilot and copilot on the AP Panel.
Jesse Saint
08-25-2017, 10:44 PM
Infinity grip wiring
Thank you Jesse for the wiring info.
A friend also provided me with the wiring info and it is on par with your info.
Thank you for the picture Ray..I was wondering if I needed to reinforce the area where I needed to drill the exit hole but looks like it won't be required.
Thanks again everyone...
Bruno
08-26-2017, 02:57 PM
Some reinforce. Some do not. I did not feel it was necessary (my opinion). Keep the hole as small as practicle and debur it like you would any other hole.
Ray
08-27-2017, 01:57 PM
Wait a minute Bruno, you had MANUAL trim on your plane?? How can that be? You have every conceivable bell, whistle and gizmo known to man and you had MANUAL trim? There are Pietenpols with electric trim!
We missed you at the Lachute flyin yesterday
Cheers
Scott Black
VAF dues 2020
Instagram @sblack2154
