Dale,
It wouldn't be much lighter. A couple of thoughts; Check th location it would come through the fuselage side. Would it interfere with anything here? If you add a 90 degree fitting here, you have added back the weight you saved. Not sure you could get it out without removing the tank. The tank is closer to the fuselage on the -6 than the other RVs and the line is going to be in the way. Just trying to make you think of all possible pit falls. If these things check out OK, there shouldn't be a problem doing it this way.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
