Go Back   VAF Forums > Main > Safety
  #31
Old 08-21-2017, 08:11 AM
uk_RV9A uk_RV9A is offline
Looks like an anti splat in this image, doesn't look like it helps the outcome any...
Old 08-21-2017, 08:34 AM
Brantel's Avatar
Brantel Brantel is online now
Yep, that looks like the way an antisplat is made with the little fork on the end.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-21-2017, 08:39 AM
868RM 868RM is offline
Default Anti splat
I think I disagree with statement that it didn't work or help There may have been a violent crash when the initial bending occurred without the brace.
Old 08-21-2017, 09:10 AM
maus92 maus92 is offline
Originally Posted by Pmerems View Post
Here is an enlarged and cropped image from the video. This item was hanging off near the base of the cowl near the nose gear leg. It falls off prior to the aircraft flipping. Looks like some sort of stiffener to me. You can also see something on gear leg that is not the same color as the gear leg. Could this be where the item was attached? Obvously the gear leg fairing is missing in the image. Either not installed or broke off.
Food for thought
It's not the Anti-Splat gear mod. The ASA attaches at the mid point of the stiffener; the frame grab appears to show that the "stiffener" has one attach point near the cowling. Maybe it is a vibration dampener?
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 08-21-2017, 09:13 AM
And in this image / perspective it does look like the ASA mod... Maybe two different parts? Or what was left of the fairing?
CA
Old 08-21-2017, 09:21 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I get the impression from many posts over the last couple of years that many folks think that the AS leg stiffener is going to solve all their problems on A models. It isn't. If you bent the leg like this and land on even slightly rough grass, almost certainly the airplane will flip.
If you hit a big rodent hole even at a moderate taxi speed, you're also likely to severely damage the support structure or flip too.
The AS device will give you a bit more margin in certain scenarios but ultimately if you put a couple thousand pounds of force backwards on the leg, it's going to bend at the engine mount support anyway.
I also see posts where people believe holding the stick full aft will have any useful effect below 20 knots with no propwash over the elevator. While it's good technique to do so, you won't even take 50 pounds off the nose gear. That's not going to save you either if you hit a hole or asphalt ledge of some sort.
Even with the best technique, if you fly off grass long enough, you could have a bad day hitting something higher than the tire to leg end clearance.
[ed. I agree! If the technique is off, no hardware is going to keep you right side up. Here's an AS from a noseover event (not the one discussed here). Just making the point that technique is the #1 determining aspect of staying upright: v/r,dr
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 08-21-2017, 09:53 AM
dmat dmat is online now
I wonder if Antisplat can confirm with the tail number.
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 08-21-2017, 12:17 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Originally Posted by rv6ejguy View Post
...Even with the best technique, if you fly off grass long enough, you could have a bad day hitting something higher than the tire to leg end clearance.
And being aware of where the CG is at the end of a flight is extremely important, too.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 03-24-2018, 10:15 AM
LykkeEspersen LykkeEspersen is offline
Default Maybe better than its reputation
First post on any forum ever....Hope it works and that I do not breach any VAF rules.
At the beginning of building my RV9A I had absolutely no idea the nose gear could fold up, ending in a flip over. Once I found out I started to read all available accident reports, videos on Utube and discussions on VAF.
Over the years it has brought me from a happy builder, over despair and all kind of plans to mitigate the risk. The more I studied the subject the more convinced I was that I - with my moderate flying skills - will end up inverted.
Well much to my surprise it has not happened - yet.....I hope I am not committing hubris though.
One of the very first things i did was adding a camera under the wing to see all 3 wheels, in order trying to describe the dynamics involved in the nose wheel oscillating. This turned out to be too complicated for me, but I did develop a sort confidence in the design, and certainly found a number of bad habits and things not to do.
I have only operated on relatively even and level surfaces. I am still convinced that if the NW falls into a pothole or meet an obstacle higher than a couple of inch the gear will dig in.
As other and new builders of A models may be going through the same despair as I did.. I thought I would make my video available for all
http://www.youtube.com/watch?v=Mr92SjkTynA
It comes with a warning: It is extremely boring and have no entertainment value at all, but if it provides peace of mind for anyone then its worth the 18 min of NW oscillation.
What surprised me the most is the last sequence of the video, where the plane actually lift of - just a few inches - and then lands on the NW without me noticing it - until second landing.
So it seems Scott was right in his reply 8 years ago: "Fly with confidence"
......And perhaps the design is better than its reputation?
Best regards
Lasse
Lasse
[color="Navy"][i]Shadow ultralight, 9-177. Sold
Pulsar 912XP OY-LLE. Sold
RV9A F-PLLE.
Piper Colt 1961 D-EDCE
Old 03-24-2018, 12:22 PM
Davy8or Davy8or is offline
Best regards
Lasse
I'd love to watch the video, but the link doesn't work. Do you still have your RV-9? Your signature suggests you donated it?
