Old 08-15-2017, 07:27 AM
sritchie sritchie is offline
Default Question on AeroLEDs grounding + shared wiring
Hey all,
I've done a lot of reading on the grounding requirements for the AeroLEDs, and I think I have a good handle on the grounding. My summary is that the grounding lines from each of the lights should NOT be joined into a single line and brought forward to the panel, but that each light on each side of the plane should have its shield brought all the way up to the firewall. Here's the thread I'm referencing:
http://www.vansairforce.com/communit...t=94927&page=3
Is this correct?
Now for my question. What about power and wig wag lines? I have a single power line for my Aerosun VXs and another for my NS90s. I'd like to use a small terminal block to split power out to each wing. Is there any problem with doing this, or do I need to have a power line for each wing running all the way from as close as possible to the panel?
Just getting my head around the massive wiring task ahead of me. Thanks a lot for your help, everyone!
Old 08-15-2017, 07:51 AM
Raymo's Avatar
Raymo Raymo is offline
I did what you are describing and it works well (zero noise). A terminal block is mounted under the passenger seat in my -7A where power comes from a 3 conductor (NAV, Strobe, Landing) shielded wire from the panel and lights are connected there, including the shield ground from each light and from the panel wire, along with the sync wire. Shielding is ground under the seat to the airframe.
No wig-wag in my setup but a 4th line could be run for that. No shielding needed.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 08-15-2017, 08:17 AM
Hey, that makes great sense. Did you also connect the passenger seat grounding block to your firewall grounding block?
Old 08-15-2017, 08:43 AM
Raymo's Avatar
No. The lights are grounded near their mounting location, per instructions. The black wire joins the shielding and is grounded under the seat, along with the shielding from the power wires from the panel..
Ray
Old 08-15-2017, 09:50 AM
Ah, okay, that makes sense. I've got a grounding block I'm using for the panel components on the firewall itself, so that I can use a passthrough bolt to ground the engine to the firewall. I was assuming you did this as well, so I was asking if you had joined the two separate grounding blocks with a grounding wire. Sounds like this doesn't apply.
(The goal here would be to save some wiring and collect the grounds before running them all back on the same wire to the main forest of tabs.)
Old 08-15-2017, 11:05 AM
Raymo's Avatar
I have the same firewall setup (FOT) and likely could have tied onto either the fuel pump or flap ground that I ran from the FOT but I've had no problem with the lights being grounded under the seat.
Ray
