Go/no go
Sounds like you have already done your homework. The hardest part is pulling the trigger. From there on its the start of a new life you want regret. There will be up's and down's. (more up's than down's) Vans has plenty of parts to reorder if and when there is a mistake made.
Like some of the post here say, jump in and get started. You will have plenty of time to read between UPS shipments. You'll be on a first name basis with the UPS man before long.
You will need a couple of good tables or benches to beat your head on from time to time. Did I mention a bottle of hydrogen peroxide and a few bandaids (blue tape works just as good)
It really helps if your wife is on-board with this project from the start. You'll need someone to help buck rivets in those tight spaces.
I almost forgot this one! Be in a public place when you tell her that she needs to park her car outside the garage for a while. Hope it doesn't snow there much.
You can do this cause you got a whole choir here on VAF. We got your back!!
Rod Estep
RV8, BPE IO-360, C/S
5yr build, 10yr Flying
Still Grinning!
Dues Pd
