Old 06-12-2019, 12:42 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Sika will not adhere without primer!
If Sika ist glued on with primer, it wont let go ...
Epoxy has nearly no adhesion on acrylic ... if you scuff very rough, you get some, but still poor. If you have to put epoxy onto acrylic, I would use primer and scuff the primer, so you get some adhesion.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 06-12-2019, 06:22 AM
maniago's Avatar
maniago maniago is offline
I deep into Sika'ing my canopy, windshield, fairings, targa strip etc right now.
Sure seems pretty odd that its bonded to the AL but not the plexi. I cant imagine a builder priming etc one side and not the other. But then I also wonder about having sika available but using screws exclusively instead.
Are you sure its really black Sika and not just black RTV that was used? Sika with primer and activator will never let go of the plexi short of grinding, though I suppose the primer could let go from the targa strip.....
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
