  #121
Old 11-11-2009, 01:00 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Default Rudi on 230 hours
230 Hours in and getting ready to rivet up the tailcone...I like this structural skeleton picture
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 11-11-2009, 05:57 AM
rleffler's Avatar
rleffler rleffler is offline
Looks good! I can't wait to see a stop animation video for the RV-10
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-23-2009, 01:27 AM
Talking 270 Hours Fit the Tail
Just finished temporary fitment of the Tailfeathers to the Tailcone (Just shy of 270 hours)
Standing back looking at the First Major Milestone, Feeling Good? YES!
Old 11-23-2009, 04:29 PM
rleffler's Avatar
Default Carbon Fiber Overhead Console
Geoff Combs (Aerosport Products) stopped by today with my new carbon fiber overhead console. I must say that I was rather impressed with the quality and fit. It fits perfectly, so I won't have to do all the sanding and filling that others have done with the fiberglass overheads. It's also significantly lighter than the fiberglass overheads too. Since it's hot off the press, or should I say vacuum bag, the access panels, air vents, and clothes hangar haven't been installed yet.
Bob Leffler
Old 11-23-2009, 08:24 PM
flion's Avatar
flion flion is offline
Does that console work with the Flightline A/C system, do you know? Looks good.
EAA Technical Counselor #5357
Old 11-23-2009, 09:07 PM
rleffler's Avatar
I don't know any reason why it wouldn't work. The concept is the same, which is a couple 2" scat tubes attached at the tailcone bulkhead. My guess is that you'll save at least 5-6 lbs over the the fiberglass overheads that I've seen.
Give Geoff at Aerosport Products a call. I know that one of the vendors was anxious to get a carbon fiber overhead. I just don't recall which one at the moment.
Bob Leffler
Old 11-24-2009, 07:18 AM
jtrollin jtrollin is offline
Default Tanks are done and have no leaks!
I am probably going to have to revise how much fuel they hold based on the vast amounts of proseal used to hold them together but it is worth it to have no leaks.
http://rv10.trollingers.com/gallery2...serialNumber=1
So I guess to get an image to work I need to point to an actual image file?
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Old 11-24-2009, 09:02 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Easiest way I have found is to have the image somewhere on the net-----I use Picasa, but there are a lot of others. I go to the site and open up the photo, right click in the photo, and click "copy image location". Then, when you are typing your message, put the cursor where you want the photo, and then click the yellow sun/mountain icon in the tool bar above the typing field, and past the image location into the window that opens up.
Try it, may take a couple times to make sense.
You must use the yellow sun/mountain icon, do not paste directly into the message.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-24-2009, 01:41 PM
I have my own webserver that all my images are on, but the software I use to run my gallery does not return the url to the actual image, but a path that the software uses to find the image and serve it up. This is done for security reasons and it seems these forums need a link to an actual image file and not a url that can render an image.
Good luck.
John - Leesburg VA
RV-10
Phase 1 Complete
798HJ Reserved
Old 11-24-2009, 02:19 PM
Phil's Avatar
Phil Phil is offline
Bob,
Nice photos.
What are you going to put in the two cut outs?
Are you going to leave it finished as is, or are you going to get it covered with a cloth or leather?
Phil
