Old 08-03-2017, 09:36 AM
Raymo's Avatar
Raymo Raymo is offline
Default Source for TNC connector pins?
I bunged a couple pins during install and hate to toss the rest of the $30+ kit just because the pin is missing. Digikey and Mouser both carry them but the minimum order is 750 (~$1500).
I don't think the BNC pins are compatible.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 08-03-2017, 09:43 AM
RV6_flyer's Avatar
I have run into stuff like this before. Typically is is cheaper to just buy a new $23 TNC connector from SteinAir.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-03-2017, 09:52 AM
rv7charlie rv7charlie is offline
Or...
https://www.ebay.com/sch/i.html?_fro...ector&_sacat=0
This stuff's not rocket surgery...
Old 08-03-2017, 10:45 AM
Raymo's Avatar
Originally Posted by rv7charlie View Post
Or...
No pins there either but looks like much cheaper kits that can be tossed, assuming the they have the correct pin.
EDIT: They're not the correct pins, at least the ones that are depicted aren't. The search continues...
Ray
Old 08-03-2017, 10:59 AM
There's no rule that says you have to use the rest of the connector that you got in the kit. Find one that fits your cable, and install it. Throw away the one you lost the parts for.
Ebay isn't the only option, but $20 (or $200) for a $2 connector aren't the only options, either.
Old 08-03-2017, 11:29 AM
Tbone's Avatar
Tbone Tbone is offline
Default Picture
Send me a picture of what you need (close up if possible). I may have what you need...
___________
Terry
RV7
XP IO360
Old 08-03-2017, 01:12 PM
h&jeuropa h&jeuropa is offline
They are available from DigiKey at $2.24 each, minimum quantity is 1.
DigiKey part number is ACX1070-ND.
Jim Butcher
Old 08-03-2017, 01:31 PM
tprevost's Avatar
tprevost tprevost is offline
The above P/N is for RG58 cable. The DigiKey P/N for a similar connector that fits RG400 & RG142 (more common in GPS installations) is ARF1135-ND and list for $6.67 each. This is for a whole connector assembly, not just the center pin.
Tom Prevost
08A
Wagabond (flying)
RV-6 (DNF & sold)
Rans S-19 (built and sold)
Skybolt & Cassutt (sold)
2020 VAF dues paid
Old 08-03-2017, 02:10 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
No, I think the TNC specifically mentioned in its datasheet for RG400 is this one at about $13 (ARF1683-ND) -
https://www.digikey.com/products/en/.../437?k=31-4452
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-03-2017, 02:18 PM
Raymo's Avatar
Thanks, All.
Looks like I'll be buying more kits but < $10 at Digikey is much better than the ACS price. Hopefully the quality is as good.
Ray
