Old 08-02-2017, 06:10 PM
RhinoDrvr RhinoDrvr is offline
Default O-360-A4A conversion to O-360-A1A
Hello all,
Is it possible on our experimental aircraft to convert a Lycoming O-360-A4A from a Cherokee 180D to a O-360-A1A with the hollow crankshaft to allow the use of a constant speed propeller?
I ask because I'd be interested in doing this as part of the next engine overhaul. Any idea what the ballpark pricing would be? Looking around it appears that a standard overhaul would be $15,000-$20,000 assuming a good core; what can I expect the conversion (if possible) to add to that cost?
Thanks!
Evan
Old 08-02-2017, 08:38 PM
RV6_flyer's Avatar
Originally Posted by RhinoDrvr View Post
Hello all,
Thanks!
Evan
IF the crank is a hollow crank, plug exists in the crankcase, and accessory case will accept a governor drive adapter, it should only add the cost of the missing parts plus governor drive adapter. In other words, it should add a few hundred dollars for new retail parts.
See Lycoming Service Instruction 1435 to see what is involved to convert.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-02-2017, 10:49 PM
So, the crank is NOT the hollow crank. The more I look at the docs, it seems the best option would be to sell the core and put the money towards a new A1A and constant speed prop.
Old 08-03-2017, 06:25 AM
RV6_flyer's Avatar
With a SOLID crank, it would be better to sell core and find another.
I would expect a NEW crankshaft to set you back somewhere around $8K.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Old 08-03-2017, 08:23 AM
659JR 659JR is offline
Default CRANKS
You can get new cranks for 4800-5000 and used when you can find them around 3600. The A4 crank would be worth about the same. I would guess if you could find someone to exchange cranks you would be looking in the 1000-1500 range to convert it over to the constant speed.
Jesse
Colorado Air Parts
970-874-7575
Old 08-03-2017, 11:31 AM
mahlon_r mahlon_r is offline
you will also need to modify the crankcase nose/front bearing bore.
see info here: http://eci.aero/pdf/04-4.pdf
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
