  #31
Old 08-04-2017, 08:17 AM
Sam Buchanan's Avatar
been here awhile
Originally Posted by YellowJacket RV9 View Post
I'd love to hear from those of have successfully gone this route, and received any credit for homebuilding.
Chris
I suspect Ironflight (Paul Dye) will jump into this discussion at some point.
He can tell you firsthand how much effort is required for a custom aircraft builder to acquire the A&P rating (Kitplanes magazine, Editor's Log, May 2017).
Sam Buchanan
RV-6
Fokker D.VII replica
Old 08-04-2017, 08:34 AM
YellowJacket RV9 YellowJacket RV9 is online now
Yep I remember that article, will have to pull it up again.(found it http://www.kitplanes.com/issues/34_5...7_21819-1.html) It sounds like the key is building a relationship with an A&P, and also keeping excellent records. It also sounds like a good excuse to go to the Lycoming school and build up the resume!
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 08-04-2017, 09:08 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
I will not speak for him but if you contact Caveman on this forum you may ask him these questions. He just completed his certification this spring doing exactly what you are discussing. I am sure he can give you a lot of insight.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 08-04-2017, 09:36 AM
rmartingt's Avatar
Chris
Well there's my downfall... if one needs a super-detailed build log by the hour, I'm hosed.
RV-7ER - finishing kit and systems installation
Old 08-04-2017, 09:53 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I actually think that editorial pretty well sums it up Sam. After getting approved, I still had to spend three weeks studying for and taking the three writtens, then ten days doing a prep class for the Oral and Practical - and taking the exam.
Simply building an airplane (or two, or three...) is not the equivalent of decades of working on a variety of airplanes, spending pretty much your whole professional life in airplanes, and having airplanes on the brain pretty much all the time.
Finally, what I think is most relevant to the discussion, is an old scene from the TV show MASH. Colonel Potter has just helped another surgeon in the OR with a suggestion that saved a patient's life. Someone says something like "Wow Colonel, you're a genius!" His response was "If I'm such a genius, how come I just stitched my glove to this young man's intestine?"
The point being that no matter how good we think we are, or someone else thinks we are, we still miss things. Inspecting airplanes is not the same as building them, or maintaining them - and it requires the humility to know that we can still let things go by without notice. I like to have others inspect my work, and while it can bruise the ego, the goal is to have safer airplanes - not pats on the back.
Training in good inspection techniques is different than building or maintaining - and perhaps that is where we should concentrate if we want a more universal inspection authority - how to do a good inspection!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-04-2017, 10:06 AM
RVbySDI's Avatar
. . . Training in good inspection techniques is different than building or maintaining - and perhaps that is where we should concentrate if we want a more universal inspection authority - how to do a good inspection!
Well Paul, outside of experience, self-education and perpetual conscientious self-improvement, who teaches that course? If that course exists let me know, I'll sign up!
RVBYSDI
Steve
RV9A
https://rvwings.com
Old 08-04-2017, 11:13 AM
rvbuilder2002's Avatar
That is the 30 months of on the job experience that the FAA requires if a formal training course has not been completed.
I agree with Paul.
The experience developed building an airplane does not develop all of the skills required to inspect an airplane. That is why in my condition inspection forum I encourage people to get assistance from an experienced A&P for at least the first year or two, even if the hold the Repairmans Certificate for their airplane.
Scott McDaniels
Hubbard, Oregon
Old 08-04-2017, 11:40 AM
Agree 100% that building a plane is nowhere near the type of experience needed to be an A&P. It's just unfortunate that there isn't a path to being licensed to work on only small, piston powered planes without going through some of the other, unrelated requirements.
Chris
Chris Johnson
Old 08-04-2017, 12:02 PM
MED MED is offline
I don't want to muddle this, but one poster said his A&P said he was not "authorized" to replace cylinders on his engine. Isn't that true if the engine is a certificated engine? I always heard to work on the engine the data plate had to be removed or in some other way the engine declared to be non-certificated - like an experimental engine for an experimental aircraft or an air boat.
Old 08-04-2017, 12:15 PM
tspear tspear is offline
No. It is BS.
Now, from a legal perspective, if you put a certified motor on an experimental; then want to reinstall it on a certified aircraft. It is legal; but the requirements any A/P or I/A would make you go through is impractical. So do not bother trying.
Tim
