Go Back   VAF Forums > Model Specific > RV-14
  #11
Old 08-01-2017, 05:09 PM
rvbuilder2002's Avatar
Originally Posted by mturnerb View Post
5. I was describing the adjustments made to relieve binding, not in relation to the stops (range was adequate if taken to stops, binding was the problem)
Then that is what caused my confusion and the reason I gave the response I did.
If I'm not mistaken, the OP was asking about elevator deflection travel and never said anything about resolving a binding problem, so my (incorrect) assumption was that you were promoting changing the rod end insertion dimension to make changes in elevator travel.....
Scott McDaniels
Hubbard, Oregon
Old 08-01-2017, 05:20 PM
Originally Posted by RV8JD View Post
BTW, I think Scott is pretty helpful here. Sometimes his reponses are short, but that may be because he replies to a lot of posts (sometimes with folks who seem to just want to argue), and I assume he has a life away from RV's and this Forum.
Correct.
And a lot of my participation here is during a break (lunch or otherwise) from my normal work so I don't always have a lot of time.
The other reason a lot of my responses are short is because it is simply meant as info for the masses (do you know there are 10,000 + lurkers here that read but never post), but lacking the time to explain "why" for every post I make.
I.E., people are free to build, do, and modify how ever they wish, but there are times when things they post can literally change they whole dynamic for our tech support staff for a couple of days when people start calling or e-mailing with the "I saw it on VAF" tag line......
I don't mean to imply that is the case with this thread..... just stating what my motivation is at times.........
Scott McDaniels
Hubbard, Oregon
Old 08-01-2017, 05:34 PM
bkervaski's Avatar
bkervaski bkervaski is offline
... I think you're well within the range of normal deviation of horn position and if you have good range of movement, why fix what's not broken?
Barely in range .. and it's bugging me .. if I could replace that horn effectively I would do it ..
You're right though, should probably let it go, it's the perfectionist in me. This build is definitely helping with my OCD!
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 08-01-2017, 06:42 PM
mturnerb mturnerb is offline
Bad on me for not being clear - we all benefit from taking care to be precise. I appreciated your taking time to respond.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
