Old 02-12-2007, 07:26 PM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default Decoding Cotter Pin Numbers
Can someone post the breakdown for understanding what cotter pin numbers mean.
Andrew Phillips
7A QB, working on fuse
Old 02-12-2007, 07:37 PM
jcoloccia jcoloccia is offline
The MS24665 numbers make no sense to me at all. The other ones go
AN380-x-y
Diameter is x/32"
Length is y/4"
Sooo....
A AN380-3-8 is 3/32"X8/4" (i.e. 3/32" X 2")
...or, you can look here if that's all you want.
http://www.aircraftspruce.com/catalo.../an310_320.php
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 02-12-2007, 08:13 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Decoder
The secret decoder ring is on this page....
http://www.gen-aircraft-hardware.com...df/ms24665.pdf
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
